I have a set of files to convert into multi-epsiode disks.
Each file goes through the process of conversion creating in turn the mpg, then demux to create the mp2 & mpv files, then pull down creating the pd file.
After svcd starts to convert the next avi file, all previous files are erased therefore when it comes to creating the final dvd, there are no mpg files to work with, so svcd generates an error to this effect.
This did not happen as far as can remember on previous versions.
Any help with this chrissy ????
Results 1 to 9 of 9
Can you post your log file?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Unfortunately Not as once programs stops with error it will give the following 3 times then quits, shutting down the program..
Version: SVCD2DVD 2.5
Build: 2.5.2725.29477
Type: System.IO.FileNotFoundException
Source: mscorlib
Message: Could not find file 'D:\Heroes\Heroes 1x01.Genesis_S2D.mpg'.
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileInfo.get_Length()
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart() -
There should still be a log, can you humor me and check here to see if one exists from the project:
Have you tried the project more than once? There was a similar error recently that went away with the next run thru.Dwight
- Herm Albright
Ok yes tried same project a number of times with same results
Found log file.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.2725.29477
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2715731
Executable CreationTime: 18/06/2007 16:23:26
Executable LastWriteTime: 19/06/2007 23:07:07
Executable LastAccessTime: 19/06/2007 23:07:18
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 1.99 GB
Free Physical Memory: 1.41 GB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.95 GB
***************************** Computer *****************************
Computer Manufacturer Name: System manufacturer
Computer Model: System Product Name
System Type: X86-based PC
Computer Name: STUART
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 2
User Name: STUART\Master
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Description: x86 Family 6 Model 15 Stepping 6
CPU Speed: 2.401GHz
CPU FSB: 266MHz
L2 Cache Size: 4.00 KB
CPU Speed: 2.401GHz
CPU FSB: 266MHz
00:56:34: Logical CPUs: 2
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: NVIDIA GeForce 7300 GS
Processor: GeForce 7300 GS
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 512 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 82.7 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 25.3 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 29.6 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 11.9 GB
DeviceID: J:
FileSystem: NTFS
FreeSpace: 14.2 GB
DeviceID: K:
FileSystem: NTFS
FreeSpace: 28.4 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="20/06/2007 00:56:34" Filename="NONE"><AssetSet><Asset ID="7acc26d8-619f-4598-ad50-65d6a84ceda2" Path="D:\Heroes" Filename="Heroes 1x23.How to Stop an Exploding Man.avi" /><Asset ID="099b8d92-4b27-48d6-959b-0c203c0e81da" Path="D:\Heroes" Filename="Heroes 1x01.Genesis.avi" /><Asset ID="9496b5f1-1fe8-42a1-b198-705bf315a705" Path="D:\Heroes" Filename="Heroes 1x02.Don't Look Back.avi" /><Asset ID="35c5d9bd-8f00-40cd-b414-70e079c94d3b" Path="D:\Heroes" Filename="Heroes 1x03.One Giant Leap.avi" /><Asset ID="8f889060-175e-40a2-a7f3-31dfb1a979a5" Path="D:\Heroes" Filename="Heroes 1x04.Collision.avi" /><Asset ID="cd795079-a4ee-4cf4-8097-4164a4c558f9" Path="D:\Heroes" Filename="Heroes 1x05.Hiros.avi" /><Asset ID="d523b8b7-336c-408b-97f3-d19613477e84" Path="D:\Heroes" Filename="Heroes 1x06.Better Halves.avi" /><Asset ID="c33a9594-3dc6-434b-803b-345b482e5dd2" Path="D:\Heroes" Filename="Heroes 1x07.Nothing To Hide.avi" /><Asset ID="55aef89f-c085-4a06-b702-88bbe776525d" Path="D:\Heroes" Filename="Heroes 1x08.Seven Minutes to Midnight.avi" /><Asset ID="655fad32-87f8-4aaf-ac79-e27e83d6c560" Path="D:\Heroes" Filename="Heroes 1x09.Homecoming.avi" /><Asset ID="9966e727-a838-4c7f-a448-85d1b48d941f" Path="D:\Heroes" Filename="Heroes 1x10.Six Months Ago.avi" /><Asset ID="525b6525-adb8-4f76-b456-c4922530053e" Path="D:\Heroes" Filename="Heroes 1x11.Fallout.avi" /><Asset ID="4ce5c72d-e778-45e4-abb6-3d21edb9a166" Path="D:\Heroes" Filename="Heroes 1x12.Godsend.avi" /><Asset ID="9d533022-cd54-4355-b4c9-30ec8cc97671" Path="D:\Heroes" Filename="Heroes 1x13.The Fix.avi" /><Asset ID="a490b3ae-0025-4138-b7ec-23915236fafd" Path="D:\Heroes" Filename="Heroes 1x14.Distractions.avi" /><Asset ID="78fdd00f-705d-407f-8ccb-12c348ed96d5" Path="D:\Heroes" Filename="Heroes 1x15.Run!.avi" /><Asset ID="4d5f9cef-d97b-4f08-a271-9f52926026ce" Path="D:\Heroes" Filename="Heroes 1x16.Unexpected.avi" /><Asset ID="cf03c44a-7024-4fa4-9351-f89fc5904f1c" Path="D:\Heroes" Filename="Heroes 1x17.Company Man.avi" /><Asset ID="da8718df-ae36-4b87-b7d0-5c469481e69e" Path="D:\Heroes" Filename="Heroes 1x18.Parasite.avi" /><Asset ID="e93dc77f-21da-4076-b686-1862ab6868da" Path="D:\Heroes" Filename="Heroes 1x19..07%.avi" /><Asset ID="5b2abbdf-df49-41e3-8a2a-c682e513c159" Path="D:\Heroes" Filename="Heroes 1x20.String Theory.avi" /><Asset ID="bbcefcc4-8397-40ab-a0dd-36a476687d1d" Path="D:\Heroes" Filename="Heroes 1x21.The Hard Part.avi" /><Asset ID="dd3f2f82-e565-4578-9798-86e13ef41946" Path="D:\Heroes" Filename="Heroes 1x22.Landslide.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="272" Y1="112" X2="435" Y2="165" FontFamily="Tahoma" FontSize="28" FontStyle="3">Genesis</MenuButton><Title Name="Heroes 1x01.Genesis.avi" AssetID="099b8d92-4b27-48d6-959b-0c203c0e81da" MplexOffset="0" /></TitleSet><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="196" Y1="201" X2="510" Y2="254" FontFamily="Tahoma" FontSize="28" FontStyle="3">Dont Look Back</MenuButton><Title Name="Heroes 1x02.Don't Look Back.avi" AssetID="9496b5f1-1fe8-42a1-b198-705bf315a705" MplexOffset="0" /></TitleSet><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="199" Y1="290" X2="507" Y2="343" FontFamily="Tahoma" FontSize="28" FontStyle="3">One Giant Leap</MenuButton><Title Name="Heroes 1x03.One Giant Leap.avi" AssetID="35c5d9bd-8f00-40cd-b414-70e079c94d3b" MplexOffset="0" /></TitleSet><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="265" Y1="379" X2="442" Y2="432" FontFamily="Tahoma" FontSize="28" FontStyle="3">Collision</MenuButton><Title Name="Heroes 1x04.Collision.avi" AssetID="8f889060-175e-40a2-a7f3-31dfb1a979a5" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-32768" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="2" DSOffsetHeight="1.75" DSColor="-16776961" DSOnOff="True" BackgroundImagePath="D:\Heroes\Heroes_title_card.j pg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 349 MB
file=D:\\Heroes\\Heroes 1x01.Genesis.avi
FormatName=avi
Num_Frames=76224
DurationInSecs=3179
Duration=00:52:59.1
VideoCodec=mpeg4
VideoFFSTNum=0
Width=624
Height=352
Standard=NTSC (Film)
BitRate=921
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=128
Audio1Channels=2
AVI2MPG: 3120kbs Full-D1
00:56:35: Looking for AVI PAR...
Pass 1/1: Processing Heroes 1x01.Genesis.avi
00:56:35: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
00:56:35: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
00:56:35: libavutil version: 49.4.0
00:56:35: libavcodec version: 51.40.4
00:56:35: libavformat version: 51.12.1
00:56:35: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
00:56:35: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
00:56:35: Input #0, avi, from 'D:\Heroes\Heroes 1x01.Genesis.avi':
00:56:35: Duration: 00:52:59.1, start: 0.000000, bitrate: 921 kb/s
00:56:35: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
00:56:35: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
00:56:35: Output #0, dvd, to 'D:\Heroes\Heroes 1x01.Genesis_S2D.mpg':
00:56:35: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 3120 kb/s, 23.98 fps(c)
00:56:35: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
00:56:35: Stream mapping:
00:56:35: Stream #0.0 -> #0.0
00:56:35: Stream #0.1 -> #0.1
00:56:35: Press [q] to stop encoding
00:56:35: [mpeg4 @ 007BBA60]frame skip 8
01:09:49: video:1209507kB audio:86929kB global headers:0kB muxing overhead 2.553514%
01:09:49: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing Heroes 1x01.Genesis_S2D.mpg
01:09:50: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
01:09:50: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
01:09:50: libavutil version: 49.4.0
01:09:50: libavcodec version: 51.40.4
01:09:50: libavformat version: 51.12.1
01:09:50: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
01:09:50: Input #0, mpeg, from 'D:\Heroes\Heroes 1x01.Genesis_S2DNTSC(Film).mpg':
01:09:50: Duration: 00:52:58.2, start: 0.500000, bitrate: 3426 kb/s
01:09:50: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 23.98 fps(r)
01:09:50: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:09:50: Output #0, rawvideo, to 'D:\Heroes\Heroes 1x01.Genesis_S2DNTSC(Film).mpv':
01:09:50: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 23.98 fps(c)
01:09:50: Output #1, mp2, to 'D:\Heroes\Heroes 1x01.Genesis_S2DNTSC(Film).mp2':
01:09:50: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:09:50: Stream mapping:
01:09:50: Stream #0.0 -> #0.0
01:09:50: Stream #0.1 -> #1.0
01:09:50: Press [q] to stop encoding
01:12:23: video:1210266kB audio:86929kB global headers:0kB muxing overhead -6.701296%
01:12:23: NTSC(Film)->NTSC: Applying Pulldown Heroes 1x01.Genesis_S2DNTSC(Film).mpv
01:12:24: SVCD2DVD: Convert2NTSC: Converting....
01:17:13: NTSC(Film)->NTSC: Muxing Heroes 1x01.Genesis_S2D.mpg
01:17:13: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
01:17:13: INFO: [???] File D:\Heroes\Heroes 1x01.Genesis_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
01:17:13: **ERROR: [???] File D:\Heroes\Heroes 1x01.Genesis_S2DNTSC(Film).mp2 unrecogniseable!
01:17:13: **ERROR: [???] Unrecogniseable file(s)... exiting.
File Size: 349 MB
file=D:\\Heroes\\Heroes 1x02.Don't Look Back.avi
FormatName=avi
Num_Frames=60800
DurationInSecs=2535
Duration=00:42:15.8
VideoCodec=mpeg4
VideoFFSTNum=0
Width=624
Height=352
BitRate=1155
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=mp3
Audio1BitRate=80
Audio1Channels=2
01:17:13: Looking for AVI PAR...
Pass 1/1: Processing Heroes 1x02.Don't Look Back.avi
01:17:16: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
01:17:16: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
01:17:16: libavutil version: 49.4.0
01:17:16: libavcodec version: 51.40.4
01:17:16: libavformat version: 51.12.1
01:17:16: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
01:17:16: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
01:17:16: Input #0, avi, from 'D:\Heroes\Heroes 1x02.Don't Look Back.avi':
01:17:16: Duration: 00:42:15.8, start: 0.000000, bitrate: 1155 kb/s
01:17:16: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
01:17:16: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 80 kb/s
01:17:16: Output #0, dvd, to 'D:\Heroes\Heroes 1x02.Don't Look Back_S2D.mpg':
01:17:16: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 3120 kb/s, 23.98 fps(c)
01:17:16: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:17:16: Stream mapping:
01:17:16: Stream #0.0 -> #0.0
01:17:16: Stream #0.1 -> #0.1
01:17:16: Press [q] to stop encoding
01:17:16: [mpeg4 @ 007BBA60]frame skip 8
01:27:46: video:965340kB audio:69339kB global headers:0kB muxing overhead 2.533103%
01:27:46: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing Heroes 1x02.Don't Look Back_S2D.mpg
01:27:46: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
01:27:46: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
01:27:46: libavutil version: 49.4.0
01:27:46: libavcodec version: 51.40.4
01:27:46: libavformat version: 51.12.1
01:27:46: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
01:27:46: Input #0, mpeg, from 'D:\Heroes\Heroes 1x02.Don't Look Back_S2DNTSC(Film).mpg':
01:27:46: Duration: 00:42:14.9, start: 0.500000, bitrate: 3428 kb/s
01:27:46: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 23.98 fps(r)
01:27:46: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:27:46: Output #0, rawvideo, to 'D:\Heroes\Heroes 1x02.Don't Look Back_S2DNTSC(Film).mpv':
01:27:46: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 23.98 fps(c)
01:27:46: Output #1, mp2, to 'D:\Heroes\Heroes 1x02.Don't Look Back_S2DNTSC(Film).mp2':
01:27:46: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:27:46: Stream mapping:
01:27:46: Stream #0.0 -> #0.0
01:27:46: Stream #0.1 -> #1.0
01:27:46: Press [q] to stop encoding
01:30:09: video:965680kB audio:69339kB global headers:0kB muxing overhead -6.699273%
01:30:09: NTSC(Film)->NTSC: Applying Pulldown Heroes 1x02.Don't Look Back_S2DNTSC(Film).mpv
01:30:09: SVCD2DVD: Convert2NTSC: Converting....
01:33:54: NTSC(Film)->NTSC: Muxing Heroes 1x02.Don't Look Back_S2D.mpg
01:33:55: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
01:33:55: INFO: [???] File D:\Heroes\Heroes 1x02.Don't Look Back_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
01:33:55: **ERROR: [???] File D:\Heroes\Heroes 1x02.Don't Look Back_S2DNTSC(Film).mp2 unrecogniseable!
01:33:55: **ERROR: [???] Unrecogniseable file(s)... exiting.
File Size: 349 MB
file=D:\\Heroes\\Heroes 1x03.One Giant Leap.avi
FormatName=avi
Num_Frames=61602
DurationInSecs=2569
Duration=00:42:49.3
VideoCodec=mpeg4
VideoFFSTNum=0
Width=624
Height=352
BitRate=1140
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=mp3
Audio1BitRate=112
Audio1Channels=2
01:33:55: Looking for AVI PAR...
Pass 1/1: Processing Heroes 1x03.One Giant Leap.avi
01:33:57: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
01:33:57: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
01:33:57: libavutil version: 49.4.0
01:33:57: libavcodec version: 51.40.4
01:33:57: libavformat version: 51.12.1
01:33:57: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
01:33:57: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
01:33:57: Input #0, avi, from 'D:\Heroes\Heroes 1x03.One Giant Leap.avi':
01:33:57: Duration: 00:42:49.3, start: 0.000000, bitrate: 1140 kb/s
01:33:57: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
01:33:57: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 112 kb/s
01:33:57: Output #0, dvd, to 'D:\Heroes\Heroes 1x03.One Giant Leap_S2D.mpg':
01:33:57: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 3120 kb/s, 23.98 fps(c)
01:33:57: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:33:57: Stream mapping:
01:33:57: Stream #0.0 -> #0.0
01:33:57: Stream #0.1 -> #0.1
01:33:57: Press [q] to stop encoding
01:33:57: [mpeg4 @ 007BBA60]frame skip 8
01:44:43: video:976923kB audio:70254kB global headers:0kB muxing overhead 2.548929%
01:44:43: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing Heroes 1x03.One Giant Leap_S2D.mpg
01:44:44: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
01:44:44: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
01:44:44: libavutil version: 49.4.0
01:44:44: libavcodec version: 51.40.4
01:44:44: libavformat version: 51.12.1
01:44:44: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
01:44:44: Input #0, mpeg, from 'D:\Heroes\Heroes 1x03.One Giant Leap_S2DNTSC(Film).mpg':
01:44:44: Duration: 00:42:48.3, start: 0.500000, bitrate: 3425 kb/s
01:44:44: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 23.98 fps(r)
01:44:44: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:44:44: Output #0, rawvideo, to 'D:\Heroes\Heroes 1x03.One Giant Leap_S2DNTSC(Film).mpv':
01:44:44: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 23.98 fps(c)
01:44:44: Output #1, mp2, to 'D:\Heroes\Heroes 1x03.One Giant Leap_S2DNTSC(Film).mp2':
01:44:44: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:44:44: Stream mapping:
01:44:44: Stream #0.0 -> #0.0
01:44:44: Stream #0.1 -> #1.0
01:44:44: Press [q] to stop encoding
01:46:57: video:977350kB audio:70254kB global headers:0kB muxing overhead -6.706121%
01:46:57: NTSC(Film)->NTSC: Applying Pulldown Heroes 1x03.One Giant Leap_S2DNTSC(Film).mpv
01:46:57: SVCD2DVD: Convert2NTSC: Converting....
01:51:04: NTSC(Film)->NTSC: Muxing Heroes 1x03.One Giant Leap_S2D.mpg
01:51:04: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
01:51:04: INFO: [???] File D:\Heroes\Heroes 1x03.One Giant Leap_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
01:51:04: **ERROR: [???] File D:\Heroes\Heroes 1x03.One Giant Leap_S2DNTSC(Film).mp2 unrecogniseable!
01:51:04: **ERROR: [???] Unrecogniseable file(s)... exiting.
File Size: 349 MB
file=D:\\Heroes\\Heroes 1x04.Collision.avi
FormatName=avi
Num_Frames=61421
DurationInSecs=2561
Duration=00:42:41.7
VideoCodec=mpeg4
VideoFFSTNum=0
Width=624
Height=352
BitRate=1144
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=mp3
Audio1BitRate=128
Audio1Channels=2
01:51:04: Looking for AVI PAR...
Pass 1/1: Processing Heroes 1x04.Collision.avi
01:51:07: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
01:51:07: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
01:51:07: libavutil version: 49.4.0
01:51:07: libavcodec version: 51.40.4
01:51:07: libavformat version: 51.12.1
01:51:07: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
01:51:07: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
01:51:07: Input #0, avi, from 'D:\Heroes\Heroes 1x04.Collision.avi':
01:51:07: Duration: 00:42:41.7, start: 0.000000, bitrate: 1144 kb/s
01:51:07: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
01:51:07: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
01:51:07: Output #0, dvd, to 'D:\Heroes\Heroes 1x04.Collision_S2D.mpg':
01:51:07: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 3120 kb/s, 23.98 fps(c)
01:51:07: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:51:07: Stream mapping:
01:51:07: Stream #0.0 -> #0.0
01:51:07: Stream #0.1 -> #0.1
01:51:07: Press [q] to stop encoding
02:01:47: video:975156kB audio:70047kB global headers:0kB muxing overhead 2.475016%
02:01:47: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing Heroes 1x04.Collision_S2D.mpg
02:01:49: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
02:01:49: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
02:01:49: libavutil version: 49.4.0
02:01:49: libavcodec version: 51.40.4
02:01:49: libavformat version: 51.12.1
02:01:49: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
02:01:49: Input #0, mpeg, from 'D:\Heroes\Heroes 1x04.Collision_S2DNTSC(Film).mpg':
02:01:49: Duration: 00:42:40.8, start: 0.500000, bitrate: 3426 kb/s
02:01:49: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 23.98 fps(r)
02:01:49: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
02:01:49: Output #0, rawvideo, to 'D:\Heroes\Heroes 1x04.Collision_S2DNTSC(Film).mpv':
02:01:49: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 23.98 fps(c)
02:01:49: Output #1, mp2, to 'D:\Heroes\Heroes 1x04.Collision_S2DNTSC(Film).mp2':
02:01:49: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
02:01:49: Stream mapping:
02:01:49: Stream #0.0 -> #0.0
02:01:49: Stream #0.1 -> #1.0
02:01:49: Press [q] to stop encoding
02:04:17: video:975156kB audio:70047kB global headers:0kB muxing overhead -6.701742%
02:04:17: NTSC(Film)->NTSC: Applying Pulldown Heroes 1x04.Collision_S2DNTSC(Film).mpv
02:04:17: SVCD2DVD: Convert2NTSC: Converting....
02:08:04: NTSC(Film)->NTSC: Muxing Heroes 1x04.Collision_S2D.mpg
02:08:04: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
02:08:04: INFO: [???] File D:\Heroes\Heroes 1x04.Collision_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
02:08:04: **ERROR: [???] File D:\Heroes\Heroes 1x04.Collision_S2DNTSC(Film).mp2 unrecogniseable!
02:08:04: **ERROR: [???] Unrecogniseable file(s)... exiting.
02:08:04: Done: Processing assets for DVD creation
Authoring DVD Folders -
ok just tried again. with only first file and same result.
Log attached...
Files play in svcd2dvd preview window.
Log files showing that svcd not recognise the mp2 files created????
svcd2dvdlog-20070621001100.txt -
Stuart. There seems to be an issue with certain mp2 files at the moment. Can you change the Audio Encoding settings to AC3 for now and i will issue a fix in the next build?
Yes will give that a try, been using 2.1 for min to convert these files.
Thanks for a great prog. -
Can you try build Build 2.5.2728 (from the website)? It should resolve this issue for you?
SVCD2DVD .mkv conversion to DVD
By paulvickery in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 21st Jan 2010, 05:28 -
svcd2dvd wont clear dvd_output folder
By geb in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 14th Dec 2008, 16:00 -
HELP svcd2dvd output too big for a dvd
By scaffers in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Nov 2008, 14:42 -
Pioneer Players wont play SVCD2DVD Creations...fix?
By alangriffin in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2008, 10:06 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36
