  1. Member koberulz's Avatar
    Oct 2006
    Australia
    I'm attempting to convert an mpg file to an XVid AVI with AutoGk. However, it keeps cropping huge areas off each side, the top, and the bottom. How can I stop it doing this?
  2. - Sometimes auto crop used with default parameters by AutoGK cannot totally remove black bars or removes too much of a movie material. In this case "Tune auto crop parameters" is very handy. Threshold defines how sensitive auto crop will be: the higher the value the more cropping will be done. To completely disable audio crop you can set threshold to 0. "Number of frames to examine" is useful parameter to change if movie is a mixture of full screen/wide screen shots, so by selecting different frames that auto crop examines you can improve cropping process. "Starting frame" can help auto crop in situation when you have a full screen logo as a part of widescreen movie, in which case autocrop might decide that the whole source is full screen. By selecting a different starting frames you force auto crop not to examine irrelevant starting movie sequence. "Force cropping" option allows you to crop additional pixels after autocrop operation (if you find that you need to always crop several more pixels you can use this option). If you disable autocrop with threshold 0 then "force cropping" option becomes fully manual crop. Remember always to check how movie looks like after you set new auto crop parameters using Preview function of AutoGK.
    http://www.autogk.me.uk/modules.php?name=TutorialEN#6
    Press CTRL-F9 to access options and disable the autocropping by enabling the "tune autocrop option" and set threshold to 0.
