    May 2007
    India
    is there SDK support for these DVD Authoring software -
    1) Muxman
    2)TMPGEnc DVD Author
    i need a DVD Authoring SDK for Adding Menu Layout, background,chapter,title
    i think these two provide all the fature.
    Parul
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I think (if I understand what you're looking for) you should look at DVDAuthor
    /Mats
    May 2007
    India
    Thanks for reply. i am looking into the dvdauthor. i just want to ask some more query
    1) dvdauthor provides Windows Vista support or not
    2) How Stable it is
    3) what about the licesense detail.
    4) what about the Technical Support
    Parul
  4. 1. Yes, as cygwin runs with Windows Vista, dvdauthor also works ('support' is quite the wrong wording for a linux application that runs within cygwin on a windows system...)
    2. If you use correct input data (video/audio/subtitle/image + control files) it's very stable
    3. GPL
    4. None
