Hello, I have been recommended in the past to use ConvertXtoDVD for putting my rmvb video files on a DVD. I did get it and burned the DVD, but despite the aspec ratio that my tv has (16:9 and automatic) I cant get the entire picture on the screen. I believe the file is 16:9. I'm using a 4.7 GB DVD-R. At this point, I dont know if the problem is the DVD player, TV, encoding process, or file type in general. Ask away for more information if it will be helpful, I i will give you what I can.
Read about it here : https://forum.videohelp.com/topic306342.html
Read my blog here.
do you mean the picture is too big OR is it too small, does it touch the sides but not the top and bottom
convertx will pad the top & bottom of the video before resizing to make the video frame 720*480, to preserve the aspect ratio, and keep objects and people the correct shape. the screen is filled with the frame but the frame has some black bars
avi's can be any dimension, dvd video can only be ONE dimension, the 16:9 is a DAR display aspect ratio.
dvd frames must meet DVD standard
to fill the screen and NOT have black space one must start out with a 720*480 video frame.
most avi's do not come that way,
to get a filled DVD frame, when converting, requires doing custom CROPPING & resizing, something not available with convertX
also the display will depend on what your TV aspect/zoom settings are
when i set mine to aspect the dvd does NOT fill the complete screen ( even retail DVDs ) if i set to zoom one, its a perfect fill of the whole screen
usually I just watch them in the aspect setting, as my player is not an up converting player.
i'm in the market for a up converting player that is UltraDvix compatible, keeping my eye on the prices and shopping -
@TheWizard - the image on a DVD can be any dimension as well. The only parts of the DVD spec that are fixed when it comes to resolution are the video resolution, and the pixel aspect ratio. Within that, the image can be any size you want, and most widescreen movies do not fill a 16:9 screen from top to bottom, if the player and screen are set up correctly (something that doesn't seem to happen in the US)
Read my blog here.
Most "wide screen" movies are not at 16:9 ratio (1.77) as is wide screen TV.
They are anywhere from 1.77(rare) to 2.4. Most are 1.88 and up, that is why when played on wide screen TV there is a black strip on top and bottom of the picture.
( no matter what country) -
yes, isn't that what i said, convertX will resize till the width fills the frame then pad the top & bottom, of the frame so it meets dvd video spec.Originally Posted by guns1inger
the same thing that happens with using fitcd & cce or some other encoder, except that we have more control over the process
yes the video image is inside the frame and does not fill the frame
I never said it did.. even with retail, I said 'video frame' dvd video frame
Avi to DVD (mpeg2enc), doesn't fit screen (noob)
By bilboshaggins in forum ffmpegX general discussionReplies: 7Last Post: 14th Dec 2008, 15:53 -
creat dvd to fit your tv screen
By projecttemp in forum Video ConversionReplies: 2Last Post: 16th Jul 2008, 08:37 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 22:49 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18
