i know i must be missing something.
dlp2 is capable of creating multi-vts dvd's which works out great cuz i have a wide-screen movie with two 4:3 trailers.
i scoured the help documentation and can't find any info on linking from one vts to another.
the trailer links in the bonus menu can't link to their respective trailers cuz they're in a seperate vts ; if i move the bonus menu to the second vts, i can link to the trailers but then the link to the bonus menu from the main menu won't work since the main menu is still in vts 1.
i've seen plenty of dvd's with 16:9 movies and 4:3 trailers, deleted scenes, etc, so i know it can be done, but how.
btw - i know i can cheat and use the trailers as motion menus but i'd rather do it right.
any help would be appreciated.
Direct link from one VTS to another is not allowed by the DVD spec.
You have to link to the VMGM domain first and then to the other VTS.
I don't use dlp2 myself, but you should be able to create something like a dummy menu in the VMGM domain which just links to the other VTS.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
thx all. i discovered the bridges after i posted. took me a while [and couple of compiles] to figure out that i need 2 for each trailer - one to make the link work and one to make the end link the bonus menu so the trailers don't loop indefinately or til the title button is hit. thx again for the help.
Hi maxwell_x
The bridge is a good think, but I would stick with WMG menu to go between VTS of different format. This is how Pro DVD structure is done.
Bridge is just creating WMG PGC on its own (at compile) to navigate between different VTS. -
thx, tinker,
i've made dozens of dvd's and for quite a while which puts me at about 3 on the expert scale of 1-10 which places me just above moderately-advanced novice, so i appreciate all input.
the bridges work fine for now but i will "tinker" with vgm's again.
on a seperate note - just created the coolest motion menu i ever have. i did one for my mother once using a transparent png i made along with the "pink panther" strolling for a pink panther cartoon dvd.
this one is an 80 sec clip from near the beginning of hellraiser with the theme for audio, the buttons and the title "hellraiser" [captured from beginning of movie] with transparent background. saw same done in a couple other dvd's - both remakes - "dawn of the dead" and "texas chainsaw massacre" and really liked them.
had to post that ; it's just exciting when you compile and it turns out exactly the way you envisioned. god, i love this. -
I know where hi is coming from.
Maxwell try to get involved with DVD Remake, than you will really have fun, or maybe you are there already.
By the way WMG menu is not any different from VTS menus. Than you can use Title and Menu buttons on your remount to go to different places.
Joining Mixed Multi Angle Into Single VTS
By werdna1900 in forum Authoring (DVD)Replies: 1Last Post: 13th Jun 2009, 04:26 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 11:28 -
multi-VTS DVDAuthorGUI-like recommendations?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 7th Mar 2008, 05:29 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 16:19
