if this is wrong forum im sorry please move
been using this guide
https://forum.videohelp.com/topic301015.html
and ive used dvd decryptor to extract the VOB and IFO from each episode of the NTSC DVD.
VOB plays fine with no audio sync problems.
Every time ive used AutoGordianKnot it comes out with a major delay of audio to video.
any suggestions or ideas?
If it's just a constant offset it's no big deal.
Load into vdubmod, select streams, stream list, right click audio and select interleaving.
set delay plus or minus. find the value and direct strem copy, , to a new synced avi.
vdub may not be ideal to actually determine the offset.
you can also try media player classic,
under play, audio, options, find delay box, and play around with it.
enter value into vdub and stream copy.
gl -
Your going from vob to avi anyway .
Set video in vdub to direct stream copy .
Set audio to direct stream copy .
Set audio delay .
Constant :
If audio behind video , set delay by using the 1800 value (push audio forward) .
If audio ahead of video , must include -1800 (negative symbol to bring it back , start earlier) .
Save as new avi , check new avi is in sync .
Yes = delete original
No = delete new avi and repeat audio delay technique to improve sync .
Audio with varied position sync issue is another problem , mostly caused by vbr audio stream ... only time and effort will fix that ... audacity can help but its a slow process .
Warning : Do not preview clips in vdub or its variants ... audio will eventually slip behind everytime .
Use any other media player to preview clip .
Note : Where you see > Next click the "Advanced Settings" button < , about midway down in that guide , clear off vbr , use cbr , less headaches later if you decide to re-encode the avi to any other format . -
it seems to be constant thru out all thie 29 episodes i did.. a 1800ms offset so now they are finished i know what to do next time .
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 14:02 -
VOB sync problems when selecting within a file
By Fishcat in forum Newbie / General discussionsReplies: 6Last Post: 23rd Feb 2009, 12:50 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
