Hi, I am new to the game of subtitiling films, especially embedding subs in a film. I just can't seem to pull it off and i am pleading with you kind people to possibly provide me with a step by step process on how to imbed subtitles (.srt) into an AVI file. Here are my specs...i am using a windows vista basic system and i am using Divxland media subtitler for the subtitle work. When i attempt to imbed a subtitle it tells me to select the virtualdub folder (which i can't seem to find), and it also says that plugins subtitler vdf is missing. Can someone break all of this down for me very simpleThanks in advance to any and all that can help.
With all that, I would try VirtualDub Mod instead, as that appears to be the type of files you are using. Here's a VDM guide for making embedded subs that is fairly easy to use:
https://forum.videohelp.com/topic272736.html
Here's some other similar guides using some different programs and methods: https://www.videohelp.com/guides/category/how-to-add-subtitles-to-a-video-5;20#5;20 -
thanks redwudz, i tried but no dice....can you reccommend another method or suggest some new software? Thanks
http://www.alexander-noe.com/video/amg/
http://www.calcitapp.com/AVIAddXSub.zip (not hard coded)
https://www.videohelp.com/tools/AVI_ReComp
http://www.simpledivx.org ... just throwing out there for interest
You should disable UAC when running any of these programs .
To turn off UAC, go to the control panel and in the search box type "User Account".
embedding subtitles help require
By atomicmak in forum Video ConversionReplies: 6Last Post: 31st Oct 2011, 12:39 -
Embedding subtitles + resize
By _mAyDaY_ in forum LinuxReplies: 7Last Post: 20th Jul 2009, 16:20 -
help, newbie with a subtitle
By damien_omen in forum SubtitleReplies: 2Last Post: 20th Aug 2008, 07:30 -
Embedding video from other sites
By py52126 in forum Video Streaming DownloadingReplies: 0Last Post: 3rd Aug 2008, 23:48 -
Newbie help,subtitle only show half
By Darkamui in forum SubtitleReplies: 1Last Post: 25th Jun 2007, 08:00
