hi, whats the best dvd to xvid converter please?
Results 1 to 18 of 18
"Best" is a difficult spec to answer. There is more than one solution. One good solution is Fair Use Wizard. It's easy for the beginner and has a lot of flexibility to serve a more advanced user also.
What's the best car, What meat makes the best dinner, Oh wait, you say you are vegan?
In other words what best are you looking for?
Speed?
Quality?
File size?
Price?
Features?
I do UltraDivx using TDA3 sine to me best is Chapters and Menus. -
Since any DVD to Xvid converter would likely use exactly the same Xvid codec, the only difference would be in the settings and the initial method to get the DVD contents to the converter and codec.
The codec is what does the conversion, not the program that uses it. And the settings used with the codec generally determine the quality, etc. AutoGK should work as well as any of the others for the Xvid encoding part. I find FairUse Wizard maybe a little easier to use. -
Total video conerter & xilisoft are very good.....Winavi also
It's nice to include the resolution to the problem so it might help someone else in the future.
Best DVD to XVID Converter?
By Tchail in forum Video ConversionReplies: 7Last Post: 25th Apr 2012, 15:37 -
Whats the best Bluray to Avi/Xvid converter
By adamf154 in forum Blu-ray RippingReplies: 4Last Post: 23rd May 2010, 22:22 -
Fastest Xvid to Divx Converter
By djparis in forum Video ConversionReplies: 12Last Post: 6th May 2009, 12:59 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36
