Looking for a VCR/DVD Recorder Combo with macrovision decorded or remover or stabilizer in the unit?
the tapes (vhs) are copywrited but are mine bought and paid for and using it for my fun,not to resell.
Peter
No name brand can sell what you want as a part of the unit. It being against the DMCA to have them in the unit here in the USA.
Buy seperates, VHS player, DVD recorder and a Stabilizer. I believe Best Buy for example had a DVD stabilizer for sale. But they need to go between the player and the recorder and I suspect that most All-in-Ones do not have the ability to do that.
Others may disagree. I myself use a TBC as it also clears up errors that can have an effect on the recorded video. The device referenced above looks like a standalone remover only and not quite what you were looking for. -
dessieclive
I can see where some of these units at the site given would work for some analog MV as in a VHS tape
But I feel that if one must use a external Box. Nothing works as well and reliable as a good TBC
I note at that site that they also claim that some of their units will remove CP from a DVD which is digital
I do not think it would but would take another look if that could be verified -
It is against the law to manufacture the kind of unit you want to buy. Any of the recent Panasonic combos ( DMR ES30V, ES35V, EZ37V, etc ) will allow you to place a device such as mentioned above between the common vcr/dvd output and one of the dvd recorder inputs. It is not quite as convenient as separates.
I think that depends what country you're talking about. It's probably not illegal to manufacture these in China.Originally Posted by trhouse
You're looking for a Sima GoDVD, they're available anywhere, most notably B&H, Crutchfield, Amazon and Best Buy.
GoDVDs are going up, up, up on ebay - Sima doesn't sell them or even mention them on their website - get one while you can. BTW: for some more cash (and much better quality without the "where the hell did the green cast come from") when you transfer:
Buy a TBC. Buy a TBC You'll thank me twice for the advice. I suffered thru two years with cheap substitutes.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
Best macrovision remover for standalone dvd - recorders
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 41Last Post: 23rd Nov 2007, 15:22 -
Macrovision decoder or remover in unit
By mysabel in forum Capturing and VCRReplies: 3Last Post: 19th Jun 2007, 15:12 -
Microvision remover or decoder
By mysabel in forum Authoring (VCD/SVCD)Replies: 2Last Post: 19th Jun 2007, 13:14 -
Looking for Microvision remover or decoder in the unit
By mysabel in forum Authoring (DVD)Replies: 1Last Post: 19th Jun 2007, 12:36
