I have a non-copy protected VIDEO_TS folder
its over 5GB
in the past TOAST 7 has been able to 'shrink' other large non copy protected VIDEO_TS in the 'video' section 'DVD-video from VIDEO_TS'
I get the error:
drive reported an error:
sense key = illegal request
sense code = 0x24
invalid field in CDB
the after 'ok' toast says cant set up track
this comes after toast does the com,pression
the file plays fine w DVD-player
anhyway around this?
thanks and cheers
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
If burning an image file works, Roxio's forums suggest:
1) Try another brand of media.
2) Check for firmware updates for the drive.
3) If you can, test with another drive.
4) If it is an external drive try another cable.
http://forums.support.roxio.com/lofiversion/index.php/t7018.html
My guess in your case would be number 1. You might try taking the unburned discs to another computer and see if they burn correctly there. -
thanks for all these tips. Ill keep them on 'file' I ended up trashing most of the VIDEO_TS and make one QT file w streamclip from one of the VOB sets
but as this happened to me once in the distant past Ill keep it in mind if it crops up again.
of note the same DVD-R blank make a fine DVD-movie on another project.
cheersMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
Copy Copy-Protected VHS to DVD
By abazabam in forum MediaReplies: 36Last Post: 12th Feb 2012, 02:25 -
Video_TS folder has no menu(s) in Toast 10
By JonnyPhoenyx in forum MacReplies: 1Last Post: 8th Mar 2009, 15:02 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
