Closed Thread
  1. Another problem I'm having is trying to fit 8.8gig video (after rendering) on a 8.5 DL disk. Is there a way to reduce the mpeg2 file size when rendering to mpeg2 using CCE basic?
    VideoSource: NTSC, Interlaced.
    Thanks.
    Matt
    Oct 2006
    Canada
    CCE Basic is good. You should be fine to compress your file to fit DL DVD with that one.
    I use this one for 65% compression of original and on 32" TV no problem.
    One topic is enough. Just reply to add new information.
    https://forum.videohelp.com/topic331682.html
    And this is a conversion issue so I'm moved the topic to the conversion forum.
