Using DV Widescreen. Didn't touch the frames or anything other than choosing DV Widescreen.
DV will be 29.97 frame per second. However, are you capturing to DV widescreen from camtasia, or only outputting from Vegas using DV ?
Many screen capture apps use very high framerates - as high as 200 fps - in order to get smooth movement. If you then render these at a lower framerate you will get jerky movement from the missing frames.Read my blog here.
Need help - rendering in Vegas
By Rairun in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2011, 19:51 -
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Rendering with Vegas 8
By seven1970 in forum EditingReplies: 27Last Post: 23rd Feb 2009, 12:44 -
Jerky rendering in Premiere 6.0
By wasimismail in forum EditingReplies: 6Last Post: 26th May 2008, 21:30 -
Vegas 8 rendering problem
By rotis in forum Newbie / General discussionsReplies: 18Last Post: 21st Feb 2008, 06:27
