Results 1 to 11 of 11
    Apr 2003
    PA USA
    I thought DVDs use MP3 for audio and VCDs use MP2. Why is SVCD2DVD converting perfectly good MP3 audio over to MP2 to make a DVD? And then, why the failure?
    Version: SVCD2DVD 2.5
    Build: 2.5.2725.29477
    Title: 2.5
    Version: 2.5.2725.29477
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
    Executable size: 2.58 MB
    Executable size in bytes: 2715731
    Executable CreationTime: 6/18/2007 09:23:26 PM
    Executable LastWriteTime: 6/19/2007 01:17:39 AM
    Executable LastAccessTime: 6/19/2007 01:17:39 AM
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 0.99 GB
    Free Physical Memory: 523 MB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.95 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: VIA Technologies, Inc.
    Computer Model: VT8363
    System Type: X86-based PC
    Computer Name: COOTIE
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 1
    ***************************** Processor ****************************
    Manufacturer: AuthenticAMD
    Processor: AMD Athlon(tm) XP 1800+
    Description: x86 Family 6 Model 6 Stepping 2
    CPU Speed: 1.532GHz
    CPU FSB: 133MHz
    L2 Cache Size: 256 bytes
    ***************************** Time Zone ****************************
    Time Zone: (GMT-05:00) Eastern Time (US & Canada)
    ****************************** VIDEO *******************************
    Name: Matrox Millennium G450 DualHead - English
    Processor: Matrox G450
    Mode: 1280 x 1024 x 4294967296 colors
    Video Ram: 32.0 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 2.67 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 83.4 GB
    DeviceID: E:
    FileSystem: NTFS
    FreeSpace: 56.5 GB
    DeviceID: L:
    FileSystem: NTFS
    FreeSpace: 44.3 GB
    DeviceID: M:
    FileSystem: NTFS
    FreeSpace: 16.6 GB
    DeviceID: N:
    FileSystem: NTFS
    FreeSpace: 42.4 GB
    DeviceID: O:
    FileSystem: NTFS
    FreeSpace: 10.4 GB
    DeviceID: P:
    FileSystem: NTFS
    FreeSpace: 26.9 GB
    DeviceID: Q:
    FileSystem: NTFS
    FreeSpace: 35.8 GB
    DeviceID: V:
    FileSystem: NTFS
    FreeSpace: 114 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <SVCD2DVD DateTime="6/18/2007 09:24:56 PM" Filename="NONE"><AssetSet><Asset ID="0021fff0-a9aa-42d6-a0ba-43ae5378cea3" Path="E:\Post-Processing" Filename="mlandsS01E01.avi" /></AssetSet><DVDStructure><TitleSet Name="Meadowlands" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="279" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Meadowlands</MenuButton><Title Name="mlandsS01E01.avi" AssetID="0021fff0-a9aa-42d6-a0ba-43ae5378cea3" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="P:\DVDBackgrounds\coloredcube s.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="E:\Post-Processing" InitialDVDFolder="D:\SVCD2DVD" InitialProjectFolder="C:\Program Files\BadgerIT\SVCD2DVD v2\Projects" InitialMenuBackgroundFolder="P:\DVDBackgrounds" DeleteS2DFiles="True" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="P:\DVDBackgrounds\coloredc ubes.jpg" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 5 mins" SkipMPA48="True" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="False" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 349 MB
    file=E:\\Post-Processing\\mlandsS01E01.avi
    FormatName=avi
    Num_Frames=67756
    DurationInSecs=2712
    Duration=00:45:12.9
    VideoCodec=mpeg4
    VideoFFSTNum=0
    Width=624
    Height=352
    Standard=PAL
    BitRate=1080
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1StreamID=[0x1]
    Audio1SampleRate=48000
    Audio1Codec=mp3
    Audio1BitRate=131
    Audio1Channels=2
    AVI2MPG: 9000kbs Full-D1
    21:24:56: Looking for AVI PAR...
    Pass 1/1: Processing mlandsS01E01.avi
    21:24:58: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
    21:24:58: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
    21:24:58: libavutil version: 49.4.0
    21:24:58: libavcodec version: 51.40.4
    21:24:58: libavformat version: 51.12.1
    21:24:58: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
    21:24:58: Input #0, avi, from 'E:\Post-Processing\mlandsS01E01.avi':
    21:24:58: Duration: 00:45:12.9, start: 0.000000, bitrate: 1080 kb/s
    21:24:58: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 24.98 fps(r)
    21:24:58: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 131 kb/s
    21:24:58: Output #0, dvd, to 'E:\Post-Processing\mlandsS01E01_S2D.mpg':
    21:24:58: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 9000 kb/s, 25.00 fps(c)
    21:24:58: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    21:24:58: Stream mapping:
    21:24:58: Stream #0.0 -> #0.0
    21:24:58: Stream #0.1 -> #0.1
    21:24:58: Press [q] to stop encoding
    22:42:10: video:2355949kB audio:74173kB global headers:0kB muxing overhead 1.989479%
    22:42:10: AVI2MPG: done.
    PAL->NTSC: demuxing mlandsS01E01_S2D.mpg
    22:42:12: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
    22:42:12: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
    22:42:12: libavutil version: 49.4.0
    22:42:12: libavcodec version: 51.40.4
    22:42:12: libavformat version: 51.12.1
    22:42:12: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
    22:42:12: Input #0, mpeg, from 'E:\Post-Processing\mlandsS01E01_S2DPAL.mpg':
    22:42:12: Duration: 00:45:12.2, start: 0.500000, bitrate: 7486 kb/s
    22:42:12: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 25.00 fps(r)
    22:42:12: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    22:42:12: Output #0, rawvideo, to 'E:\Post-Processing\mlandsS01E01_S2DPAL.mpv':
    22:42:12: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 25.00 fps(c)
    22:42:12: Output #1, mp2, to 'E:\Post-Processing\mlandsS01E01_S2DPAL.mp2':
    22:42:12: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    22:42:12: Stream mapping:
    22:42:12: Stream #0.0 -> #0.0
    22:42:12: Stream #0.1 -> #1.0
    22:42:12: Press [q] to stop encoding
    22:46:18: video:2358327kB audio:74173kB global headers:0kB muxing overhead -3.049236%
    22:46:18: PAL->NTSC: Applying Pulldown mlandsS01E01_S2DPAL.mpv
    22:46:19: SVCD2DVD: Convert2NTSC: Converting....
    23:10:20: PAL->NTSC: Muxing mlandsS01E01_S2D.mpg
    23:10:21: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    23:10:21: INFO: [???] File E:\Post-Processing\mlandsS01E01_S2DPAL_pd.mpv looks like an MPEG Video stream.
    23:10:21: **ERROR: [???] File E:\Post-Processing\mlandsS01E01_S2DPAL.mp2 unrecogniseable!
    23:10:21: **ERROR: [???] Unrecogniseable file(s)... exiting.
    23:10:21: Done: Processing assets for DVD creation
    Authoring DVD Folders
    Type: System.IO.FileNotFoundException
    Source: mscorlib
    Message: Could not find file 'E:\Post-Processing\mlandsS01E01_S2D.mpg'.
    InnerException:
    StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileInfo.get_Length()
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    European DVD Video, support MP2 (musicam) for audio.
    American DVDs use AC3 for audio (not mp3)
    Apr 2003
    PA USA
    Whoops! Sorry! I had my "3s" mixed up.
    Ok, that answers the first question and now why the failure? Chrissy?
  4. Appears to be an error with the audio file. Does the file "mlandsS01E01_S2DPAL.mp2" exist? Can you play it (should play in WMP, at least it will on my PC)?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Apr 2003
    PA USA
    No, I have the program set to remove the temp files at completion and so the .mp2 disappeared. I'm in the middle of doing another convert but this time resulting in a AC3 audio track rather than MPEG. We'll see how it goes. If it works then I'll give MP2 a try again just for the heck of it.
    For what it is worth, the source .AVI had no problem with audio.
    Apr 2003
    PA USA
    Update: Must have been a one-time glitch. AC3 worked fine and the second try with MP2 also worked ok.
    Jun 2007
    ok i have a similar prob in that it wont recognise the mp2 files.
    and because of this it then deletes all the converted files. and quits with an error.
    Just trying to check with previous versions..
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok. For now i would recommend choosing AC3 in the Audio Encoding settings. I will fix this in the next release.
    Apr 2003
    PA USA
    I want to correct what I wrote above. It turns out that my second attempt at doing the convert to MP2 wasn't for MP2 after all. I had thought I switched it back to MP2 from AC3 but the setting change must not have stuck. I actually did the convert as AC3 again and didn't realize it. I just did a MP2 convert (double checked this time) and it failed again.
    That's alright because I learned something by the experience in that since I'm in North America I probably should have been using AC3 all the time anyway.
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you try build Build 2.5.2728 (from the website)? It should resolve this issue for you?
    Apr 2003
    PA USA
    Just downloading it now. Thanks! I'll give it a try over this weekend and let you know how it goes.
