I have a sony camera that I recently bought and I have to edit a few videos of some weddings, tourneys and a few other things to get into practices on editing. Problem is that my pc(I build it myself, don't like prebuilt) will give me the indication when I plug the usb cord in it makes the sound as if it reconizes it but doesn't reconize the hub when I plugs it in. It also doesn't reconize the video that is being feed out from my camera but yes my laptop does, I don't know what it can be and why it is doing that, hopefully you guys can help me with this. I am using Canopus and Sony Vegas7 for software editing also, hope I explain it where someone can help out with this.
Q: doesn't reconize the hub when I plugs it in
Are you saying your plugging the camera into a usb hub that is connected to the pc ?
If so , dont do it that way ... hubs and usb devices dont always work well together .
My hdtv usb receiver works fine connected directly to the pc ... but add a usb hub ... it can detect the device ... and thats as far as it gose ... useless .
However , my avertv usb2 capture device will work via the powered hub .
If the camera is connecting directly to desktop , did you install the package software from the cd that came with the camera onto this pc ... easy thing to overlook .
Also check asus for updates related to your motherboard , bios especially ... theres been quite a few very unhappy customers when it comes to usb on that board .
Do a search by google on motherboard model , and chipset used , may also dig up other help links .
What turned up form google on aus p4p800 - some reading that might help
http://hardware.mcse.ms/archive69-2004-9-86080.html < really worth reading , might give an idea to sorting issue .
Some Videos Won't Sync to iPhone
By LegendaryLero in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2011, 08:24 -
Iphone 4 videos won't play on PS3
By BrianK in forum Video ConversionReplies: 2Last Post: 17th Aug 2010, 19:35 -
Newbie only know how to use DVDSanta, but it won't convert some videos
By HartsVideo in forum Video ConversionReplies: 18Last Post: 19th Oct 2008, 20:42 -
Can I rip videos of my DVD to my computer?
By LoveKota in forum DVD RippingReplies: 6Last Post: 15th Feb 2008, 02:36 -
I want to know how to save videos from veoh to my computer?
By chriskimber in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2007, 18:36
