First off let me say I'm new to Vegas so I apologize if this is something fairly easy to do, I just haven't figured it out. I am going to make some video clips and I want to add text on the screen while the video is rolling. I was really inspired to do this when I saw History Rocks on the History Channel where they used historical video footage and songs from the time period, and then had text inserted explaining the historical significance throughout each piece. I want to do something very similar. Audio is figured out, I just need to know how to insert the text. Advice? Thanks!
Media Generators : There are basic text generators, and there are title generators.
Another approach is to create the text as long still images in .png format with a transparent background, then use Track Motion to scroll them up the screen.
So many options . . . . . .Read my blog here.
Thanks for the advice. I figured out an option in Vegas on my own, so hopefully this can help somebody else down the road. In Vegas, when you insert the text media, make sure its on it's own video track, and that's its on track 1. I tried it on track 3 (main video on track 1 and audio on track 2) which didn't work, but it did work successfully when I switched in to track 1.
Sony Vegas - Rotate Characters in Text On Their Own Axis?
By RrCoX22 in forum EditingReplies: 1Last Post: 3rd Jan 2012, 21:16 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 07:31 -
Question about this forum - rollover baloons for certain text?
By Mylo in forum ComputerReplies: 2Last Post: 13th Apr 2009, 11:17 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
Vegas 8: Overlay text in multimcamera mode?
By stantheman1976 in forum EditingReplies: 0Last Post: 4th Feb 2008, 13:08
