I captured a mini dv tape with Windows Movie Maker, this gave me a single AVI file.
I tried WinDV but a single tape was captured in about more than 40 AVI smaller files, why?
I guess I will use WMM instead, so I don't need to re-join all these avi files that I get with WinDV.
				Results 1 to 12 of 12
	To get a single file with WinDV you need to set the discontinuity threshold to 0 and the max avi size (frames) to something like 150000. "Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
	Darn, so that means I will have to recapture that tape again..!!
	Why? Just import all the files in sequence to Movie Maker. Movie Maker doesn't care if you have one or separate files. Actually separate files work better if you want to trim the clips.Originally Posted by geek2330
	Yes. Drag each clip to the timeline in the order you want. You can trim the front or back of each clip.Originally Posted by geek2330
 For export use DV-AVI standard not wmv.
	It'll work great with the video side, but I'd bet there are glitches at the boundaries of the clips in the audio side.
 Safer alternative is to recapture.
 Buy My Books
	Well, I will just recapture that tape with Windows Movie Maker and get a single continuous AVI file.
 Buy My Books
  x264 single pass generating corrupt AVI filesBy timmus in forum Video ConversionReplies: 3Last Post: 20th Nov 2010, 14:44
  WinDV - Stop capture at tape end?By stantheman1976 in forum Capturing and VCRReplies: 8Last Post: 18th Jan 2009, 21:03
  *.avi files captured from miniDV tapes with WinDV no longer playsBy gho in forum Software PlayingReplies: 5Last Post: 1st Jul 2008, 22:51
  How To Split Single DV AVI file into Multiple DV AVI files using Time StampBy insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
  iMovie converting 16:9 DV-AVI and DV Tape to 4:3 *.dv files.By Cyrax9 in forum MacReplies: 4Last Post: 20th May 2007, 04:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
