Used both Windows Movie Maker and WinDV (just for the heck..)
Now, I understand thaat I need an encoder software (grrr...haven't found freeware that works for me, trial version has nags....).
If I want to edit the video do I do this prior to encoding to MPEG or after?
Also, what about if I have a few AVI files (a few tapes....!!!), each tape is about an hour, which I think will deliver about a 12GB file or so, what should I do with those few separate AVI files? Not sure what an AVI 12GB file will be as MPEG, I assume it'll be smaller. Need advice to combine, if possible, this into a couple DVDs.
That's a depends question, many editors/authoring tools have onboard encoding. You can import the DV-AVI's make your edits and export as MPEG or direct to DVD if it has DVD authoring ability.Originally Posted by geek2330
That depends on the bitrate, on the highest quality you get about 1 hour on single layer DVD. You can get many hours on DVD but as the time increases the quality drops. You can get 1.5 to 2 hours at a very good quality.Not sure what an AVI 12GB file will be as MPEG, -
Do your editing prior to encoding. This has two benefits. First, you aren't encoding more than you need to. Second, DV avi is designed for editing, and most editing tools work well with it. Mpeg-2 was not designed for editing, and many editors don't like it at all. There are specialist mpeg2 editors, but if you edit first, you won't need to use one.
DV is around 13 per hour of footage. If you have used a tripod and kept the camera steady, you should be able to get around 90 minutes to a disc. If you have gone hand held then you should probably aim at around 60 - 65 minutes per disc.
For authoring, look at GUIForDVDAuthor, which is free and powerful. You do have to encode your footage first. There are several free encoders, from ffmpeg and bbmpeg through to quenc and HCenc. None of them are as simple to use as the commercial encoders, but something like HCEnc is capable of producing results that are just as good. Most require a basic avisynth script to load the video, which can be a bit daunting for newbies. I don't know of a simple gui interface for them to help ease the pain.Read my blog here.
Issue with captured video: 673GB AVI = 4.19 sec??
By photodyer in forum Capturing and VCRReplies: 6Last Post: 27th Jan 2011, 04:06 -
i captured a video from reciever in .mpg format, [ a conversion problem] !!
By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 17:22 -
Captured S-VHS format
By Rinsin in forum Capturing and VCRReplies: 24Last Post: 28th May 2009, 13:05 -
Convert Any Format to DVD-Video/AVI/Mobile
By lostinlodos in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 19:36 -
Software To Crop A Video & Encode It In .avi Format
By rahul.never2far in forum Video ConversionReplies: 2Last Post: 25th Sep 2007, 03:50
