Hi,
I own a VHS of a macrovision protected movie that is currently not available on DVD. Unfortunately I no longer own a VCR. Untill they release it on DVD I would like to copy it to my PC and to a DVD-R. I have a TV in card but the tape is macrovision protected. Is there anyway I can do this?
Thanks,
Results 1 to 15 of 15
~dev
Without a VCR ? Very difficult. Macrovision prevents the 'copy by osmosis' method required when a VCR isn't present.
Assuming you can get a VCR, you still need either a full frame TBC or one of those cheap 'video enhancer' units to sit between the VCR and your video in port to strip out the signal corruption.Read my blog here.
Where's the VHS tape slot?Originally Posted by pinetop
Of course I realize I need a VCR to copy it. I can borrow one to do the copy but do not own one to watch the film whenever I want. That was the point... lol. Actualy I thought there was some software or driver solution I could use with my DVR software.Originally Posted by guns1inger~dev
if you own a digital video camara and fire wire in your computer this are the steps
1 hoock up your camera with the computer using the apropiate cables
2 remove the tape from the dv
3 insert the vcr and open the capture software in your pc
3 start recording -
Some TV/capture cards are forgiving of macrovision and some (most?) aren't. And even if they are, macrovision can still mess up the picture quality. There is no software that can fix/overcome this, but those inline devices can. And BTW, you'll need software to convert, author and burn to DVD your captured movie. The how-to guides are a good place to start.Originally Posted by devnulllore
P.S. You'll soon discover that this conversion for the first-timer is not for the faint of heart or wallet. I hope that film is very dear to you, or you have several others to convert. Good Luck!Usually long gone and forgotten -
You might be able to find a older vcr which ignores macrovision. If they are still around....??
I have an old Emerson that doesn't have a clue as to what Macrovision is. Unfortunately, it also only has mono out, sucks.
Playback was always good, provided you were fast cranking the tracking knobs in a pinch LOL.
It's fast becoming a classic - still working after 20 years....;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
ATI TV Wonder Pro. Captures to MPEG2. Very good quality too.Originally Posted by pinetop~dev
Having a VCR to play the tape certainly will help.
You don't need one that captures in MPEG2, you need one that doesn't care that it has macrovision protection or a TBC, or one of those stabilizers that will remove the signal before it gets to the capture card.Originally Posted by pinetop
I'm not completely familiar with it but from my understanding that would only apply to the VCR you are using to copy another tape. The MV is embedded in the video and is passed along no matter what VCR you are using. Also from my understanding this will affect most VCR's. Most can't ignore it, the original MV took advantage of the limitations of the first VCR's. It was later made law that VCR manufacturers couldn't fix these limitations, effectively hobbling them. At least that's my basic understanding of how it works.Originally Posted by Marvingj
Perhaps yours was bought in the interim?
How go i get the same vhs quality when capturing and converting to dvd?
By Whuntmore in forum MacReplies: 43Last Post: 28th Feb 2010, 05:30 -
capturing vhs to hdd/dvd
By zulubase in forum Capturing and VCRReplies: 5Last Post: 17th Feb 2010, 23:02 -
VHS to DVD capturing, workflow, equipment
By coolmen777 in forum Capturing and VCRReplies: 14Last Post: 8th Oct 2008, 04:22 -
Capturing from a Telenet Digicorder to VHS/DVD
By InfernoZeus in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2008, 05:44 -
restore and capturing VHS to convert to DVD
By WeatherSTAR-XL in forum RestorationReplies: 4Last Post: 16th Jun 2007, 18:37
