Supposedly 1 pass encoding on version 2.5 has been optimized so that using 2 pass is no longer needed. Has anyone done a comparison between the two? Is one pass just as good as two passes would be?
Thanks,
Mark
I actually have a few issues with 2-pass these days. Its sometimes fails so I only get a fraction of video where 1 pass works. I think I read about this somewhere else?
The version of ffmpeg is the latest and there have been many improvements to the encoder. Also different settings are been used. That said, different source types may give different results (v2.1 v v2.5) - action, animation and so forth, so when you compare - compare like for like.
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 05:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 21:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 05:46 -
SVCD2DVD+Video Coding pass problem
By Interface in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Jul 2007, 14:52
