Maybe I've just missed it, but I can find virtually nothing in the Womble MPEG Video Wizard (DVD) Help about how to use the Bookmark window and its features. FWIW, I am likely to be using these in the 'Scene' mode, i.e. getting Womble to create them automatically from my main clip. Can anyone point me to some detailed documentation or answer any of the following please.
1. What exactly are the entries shown in the bookmarks window? IOW, how do they relate to what is
- selected in Clips pane
- in the Input monitor
2. What does a green entry mean?
3. Are the buttons below (Add, Split, Scene) used to create an entire new set?
4. When/why would you check an entry's box?
5. What is the purpose of the Drag button?
6. What are the meanings of Step and Start?
7. What is 'Filter Bookmarks'? (I gtried it and it apparently did nothing, nor offered me any dialog.)
8. How/when would you use 'Merge unchecked clips'? Why would I want to do that?
9. I'd expected that a 'bookmark' could be given a meaningful name, describing that particular scene. Are times (hh:mms:dd) the only labels?
10. Most important of all: how are you meant to use this tool in practice? A demo or tutorial would be great...
Best wishes,
Terry, West Sussex, UK
Results 1 to 1 of 1
is womble mpeg dvd wizard the program i want?
By meganann in forum EditingReplies: 3Last Post: 9th Feb 2009, 00:33 -
Womble video wizard mpeg dvd
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:47 -
Frameserving Womble Mpeg Video Wizard
By tmw in forum Video ConversionReplies: 13Last Post: 1st Nov 2008, 08:53 -
Womble MPEG Video Wizard destroys audio?!
By noemi7 in forum EditingReplies: 3Last Post: 16th Jun 2008, 10:18 -
settings for Womble MPEG Video Wizard DVD
By Vril-ya in forum EditingReplies: 0Last Post: 20th May 2008, 19:18
