    Jun 2007
    Well i usually use virtualdub but on some files i get like problems with combining the files due to the audio and etc. so i was wondering is there another program out there that i can use to combine the files?
    Feb 2004
    Australia
    Its a huge area to cover , but to join video clips usually requires they have the same parameters when it comes to video and audio .
    Super also includes this feature under the "use directshow" option , but files must be the same just in the case as for vdub .
    Under directshow option is , join , add customised water mark , fadein , fadeout .
    Super can also convert pal / nstc in a similar fashion as used by ulead video studio .
    Depending on what clip gose first in vdub , I would use either gspot or media info to check what the parameters for codec , video scale and bitrate are , and same things for audio for clip 1 .
    Then do the same thing for clip 2
    Then using the parameters found in clip1 , these would be applied to clip 2 , resaved as new clip2 , then combining the two can take place .
    A bit of fiddling about , but works .
    You might also look at convertxtodvd ... if you want to go to dvd , but even it can choke .
    USA
    If you could combine two dissimilar files, I would have my doubts that it would play properly. It's usually best to make them all the same before appending to avoid audio and video sync problems. Are these just a bunch of short files?
    If it's two halves of a video that you are making into a DVD, you can just encode them separately and let the authoring program 'join' them.
    Jun 2007
    Its two 700mb files im trying to join together. they go together also. but when i try to append them together with vdub it gives some error with i think is with the audio but i checked it all and it says everything is the same as the other on the size of video/audio.
  5. Member steveryan's Avatar
    Jan 2003
    Manchester
    Try avidemux instead.
    He's a liar and a murderer, and I say that with all due respect.
