Hello,
I have been capturing interlaced ntsc tv with picvideo mjpeg codec via my capturecards rf input. I used to use s-video and composite but since moving to a new house and placing my computer in a different room I am now only limited to rf input.
I am looking for avisynth noise filters to clean up my captures. I have tried convoultion3d using this guide by Fulci Lives.
Since convoution3d is a few years older I was wondering if there was anything newer that might be better or faster. Thanks for any suggestions.
Donadagohvi (Cherokee for "Until we meet again")
FFT3DFilter (not fast but good):
http://avisynth.org.ru/fft3dfilter/fft3dfilter.html -
Thank you! I will try it!
If anybody else has any others to suggest I will try those as well.Donadagohvi (Cherokee for "Until we meet again") -
fft3dfilter is great. Read the docs, as you have to download a support dll and put it in your C:\windows\system32 folder.
fft3dfilter will also reduce color noise by specifying the UV planes you wish to address -
fft3dfilter(sigma=9,plane=1) will clean up a lot of green noise
Fluxsmooth is fast and very nice
DegrainMedian is also great. Strong.
AviSynth 2.5x and Convolution3D guide for AVI captures
By FulciLives in forum User guidesReplies: 136Last Post: 21st Dec 2010, 23:47 -
Do I need a noise filter for Senn plug-on transmitter ?
By AAC in forum AudioReplies: 1Last Post: 15th Aug 2008, 12:55 -
Video: noise reduction filter for MPC
By bonanza in forum Software PlayingReplies: 1Last Post: 9th May 2008, 11:18 -
How to use Convolution 3D filter in VDub? Is it the best for noise rem?
By Srivas in forum RestorationReplies: 8Last Post: 8th Dec 2007, 19:59 -
Which Noise/Pixelation filter would be best for this video?
By mlong30 in forum RestorationReplies: 3Last Post: 17th Jun 2007, 18:03
