once i open up nero vison 4, and export a video file using the DVD template, once its exported using AC3 2.0 audio or stereo or AC3 5.1, the end product comes up as mono, does anyone have the same prob or is there anyone who can help me?
basically, i just ripped my michael jackson dangerous short films dvd using dvd decrypter, i ripped it by cell ID so i can get the music videos individually, so they are vob files, i then tried to export them using nero 7 ultra, and that problem arrived.
this is the video information for all of these vob files:
Video:
Stream:
Type: Encrypted and Interlaced MPEG2
Bitrate: 8.000 Mbps
Framerate: 25.000 Hz
Resolution: 720x576
Aspect ratio: 4x3
Audio
Stream:
Type: Linear PCM
Bitrate: 1536 Kbps
Number of channels: 2
Sampling Frequency: 48khz
Sampling Bits: 16
Volume Boost: On
Quiet Mode: Off
LFE: Off
Prologic: Off
Dual Mode: Off
Nero reconverts the audio. Use something else like tmpgenc dvd author, dvd-lab or a free tool like guifordvdauthor.
well, i want to convert my vob files into an HIGH QUALITY xvid video, i've used other programs but it comes out all pixelated, i converted from vob to mpeg2 and the quality came out excellent its just that the sound comes out stereo ocassionally and mono usually, is there any special ID tag thingy that i can use to make sure its actually mono, i am 99% sure though its mono, i use the dbpoweramp IDtag viewer.
i dont want to author anything, i just want to rip the dvd to get music videos, make them into high quality xvid videos so i can watch them on my PC instead of the use of the DVD -
Please include more information and I don't have to guess what you want in the end...I guessed a dvd...
Vob is mpeg2, no need to convert anything. Convert directly from the dvd or vob to HIGH QUALITY xvid avi using AutoGK, FairUse Wizard or AVi.NET. -
Well I have pretty good luck just using Vdub Surround with the Xvid codec installed.
http://www.softpedia.com/get/Multimedia/Video/Codec-Packs-Video-Codecs/VirtualDubMod-Surround.shtml -
thankyou, thats what i needed, cheers, sorry if you didnt understand me earlier, but for nero to work with xvid earlier, i have to change vob to mpeg2 (i know its the same) because it would recognise it
Powerdvd 10 3D Ultra how well does it work for converting movies to 3D?
By slowmost in forum Software PlayingReplies: 2Last Post: 26th Jun 2010, 23:53 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 06:16 -
Nero 7 ultra screws up Windows Media player 11
By shaggy90506 in forum Software PlayingReplies: 5Last Post: 2nd Nov 2007, 20:03 -
Nero 7 Ultra Edition Aborts DVD to Burn
By uLmighty in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2007, 02:02 -
Nero 7 Ultra only offers 1080p, and no 720p???
By carlitos287 in forum Software PlayingReplies: 1Last Post: 6th Aug 2007, 01:30
