Hello all.
I downloaded some XVID files and can't understand why XBMC won't play them.
Here are the file specs:
512 x 384
Audio MPEG Layer-3 96kbps
Video Frame Rate 29 frames/second, data rate 122kbps
Size 349MB
Duration 0:48:31
They are BBC shows so maybe it's because they were in PAL format or is it the aspect ratio?
How can I convert them so XBMC will play them?
Thanks.
Network permissions weren't set on the files.
Now they play, but thanks for the help anyway.
App for converting .vob folders/files to DIVX or XVID?
By Newb787 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2011, 14:21 -
Converting .TOD files for use in XBMC using FFMpeg
By duckredbeard in forum Video ConversionReplies: 9Last Post: 6th Aug 2010, 07:42 -
Certain XviD files won't play
By Towin in forum Software PlayingReplies: 2Last Post: 10th Dec 2009, 18:01 -
does the playstation 3 play divx or xvid files?
By Onceler2 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2008, 12:25 -
How do i play XVID and DIVX files with my Vid-out (Radeon 9200) on my TV
By azman666 in forum Software PlayingReplies: 2Last Post: 13th Jun 2007, 22:09
