    Feb 2007
    On Earth!!
    I was watching internet tv from a while sometimes the buffering is too much, though the connection was Downstream 15860, Upstream 1016.
    Is there anyway to resolve this problem, that I could enjoy internet tv without buffering??
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I don't know if it will help but there is a program that I use for youtube videos that helps with that problem called speedbit video accelerator.
    Donadagohvi (Cherokee for "Until we meet again")
    Feb 2007
    On Earth!!
    Thanks Freebird!!
    the website, showing internet tv playing tv on wmp (its already on their website - yes just like youtube)
    I will let you know. Hy, thanks once again for your help.
    Feb 2007
    On Earth!!
    i did install it, but it is only helping youtube, as the icon showing it, and showing latest youtube vidoe on icon.
    But do you know how could i set this program with internet tv website, i tried but didn't find anything.
  5. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Well after checking the download website it seems that speedbit only works for youtube. Sorry I couldn't be of more help. Hopefully someone else will have another solution.
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Is that what they told you or what it is? You can check it here: http://www.speakeasy.net/speedtest/
    Could be happening for a vartiety of reasons and even be the server which you would have no control over. You could try setting the buffer higher, the initial time the video starts playing will be slower but you won't get any breaks.
    Feb 2007
    On Earth!!
    No they didn't told me i could check on my modem setting its call livebox. it was correct streaming while i had buffering problem. but tell me how could i set the buffer setting?
    hy, thanks for your info.
  8. Banned
    Freedonia
    You seem to have overlooked the obvious answer, which is that the problem isn't on YOUR end but on the OTHER end - the server side.
    You may get slow response from a video server because
    1) the server may have bandwidth limits and they are trying to stay under those
    2) there may be a lot of demand on the server and it's doing the best it can
    3) the server may be old and unable to keep up with an unforeseen demand on it. This happens all the time on small servers that get discovered by large numbers of people.
    There's no fix for server side problems until they want to fix them by paying for higher bandwidth, faster servers, etc. To be blunt, there's not enough bandwidth for reliable TV viewing on the internet and you should just be glad when it works with few problems because in the USA we are many YEARS away from this working for us reliably. It will work for most of the rest of the developed world years before it works for us because of our privitized communications companies that see no value in upgrading the infrastructure to make this work.
