Hello i have bought a LG RH266 HDD/DVD and have it hooked up to my Xbox360 so i can capture some online gameplay,
My problem is once a have captured it put it on disc then ripped it on the PC it is going to need some major editing, and maybe converting so the file will be smaller if i want to upload it to the net, i was also thinking about adding some music
any help or advice on software would be great
Mpeg Video Wizard if you want to edit dvd/vob/mpeg2.
Hi...
This can be an easy task if you spend some money on software...or
a little more advanced but more flexible if use different freeware programs...
I dont know what format you source have but I expect it wold be a mpeg2 or mpeg4 video clip..
Here it goes
use VirtualdubMOD to edit the video encode it without any audio...this format
could be xvid (encoder must be installed)....
Reopen the video file and see how long it is...add the audio with the same lenght...
start the frame server (Avisynth must be installed)
and save the .vdr file with the name ex.. 'conv.avi' hit enter
open notepad and paste this line AVISource("conv.avi")
save the text file with the file name conv.avs in the same lib as your conv.avi file...
start WMNicEnc
open the .avs file
use Windows Media Audio V9.2 32 kbps, 32kHz stereo CBR
and Windows Media Video 9 Bitrate 302000
If you are in PAL country and use 320x240 as output you will get a .wmv file that
will stream with approx 330kbit....size about 1.5Mbyte per min...
This is a very short explaination, but it will give you some hints how it can be done...
If you think this way is too complex play around with Windows movie maker and see what
results you will get...
stars....
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 21:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
DV Editing
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2008, 01:48
