    Jul 2003
    Over the weekend I've started playing around with avisynth and I would like to know if I'm doing anything wrong. I'm using my WinTV PVR-150 to capture 720x576 picvideo mjpeg with the compressor set to 19. I then use the following basic avisynth script to denoise and resize -
    LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Convolution3d.dll")
    DirectshowSource("capture.avi")
    AssumeTFF()
    SeparateFields()
    odd=SelectOdd.Convolution3d (preset="vhsBQ")
    evn=SelectEven.Convolution3d (preset="vhsBQ")
    Interleave(evn,odd)
    Weave()
    Spline36Resize (352,576)
    Then I use frameserve to graphedit and convert to dvd mpeg using the ATI Avivo codec (very fast mpeg-1/2/4 WMV9 and H.264 codec)
    Am I doing anything wrong in the script? What is the best resizer in avisynth for downscaling from 720x576?
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Wrong? Only if you're not getting the results you want.
    Things I might change...
    AVISource() instead if DirectShowSource() if the source is Type2.(Edit: Sorry, missed where you're using mjpeg, not DV-AVI. Ignore this.)
    I personally would use Lanczos4Resize() for resizing because IMO it does a better job both ways than any other, and I would resize while the fields are split (although in your case it should be OK), but I don't know why you're resizing at all since you say you're encoding for DVD. I'm not familiar with graphedit or the encoder you mention so I can't comment on them other than to say if you're happy with the results, keep using them. If not, try HCEnc. IMO it does an excellent job and it's free.
    Buy My Books
  3. Member Soopafresh's Avatar
    Jan 2004
    Convolution3d is an old plugin. Try some newer ones when you get comfortable.
