I got this AVI file with XVID and tried to cut it with Virtualdub. I use Shift-arrow to move b/w key frames. However, the displayed key frame is off. If I start to play after moving to the next key frame, it immediately jump to some where else. I used Save as AVI w/ direct stream copying, hoping remuxing would fix it. No, still the same.
Any way to fix this file?
Results 1 to 12 of 12
It's because of the B-Frames. Figure out where to cut by choosing the time where the cut is to be made, and not the picture of the frame. Get the time by playing the AVI.
I've heard somewhere the some hardware DVD player can't handle packet bitstream. Is that a problem?Originally Posted by jagabo
Yes, some Divx/DVD players aren't happy with packed bitstream. You can always remux without it again after you've finished your editing.
Not true at all. All DivX players love packed bitstream since that is what DivX uses. The problem is packed bitstream together with more than one consecutive bframe, since only the first gets packed (only the first needs to be to solve the VfW problem mentioned above). Still most players received firmware updates which solved the problem. You could also check out avidemux for editing.
Yeah, my first player didn't like XviDs with packed bitstream and 2 B-Frames. It stuttered. But I never had any trouble cutting AVIs using the method I suggested earlier.
So what you're saying is some players don't like packed bitstream?Originally Posted by celtic_druid
Well no. I am saying that all DivX certified players like packed bitstream. Even those that aren't certified should have no problems with packed bitstream.
What I am saying is that some players (mostly MTK based players with out of date firmwares) can't handle multiple consecutive bframes together with packed bistream.
So there are two conditions that need to be met.
1) Packed bistream.
2) More than 1 consecutive bframe.
1 bframe + packed bistream should be fine. Same goes for 2+ bframes that aren't packed.
To claim that it is just packed bitstream is wrong. Saying that such players can't handle more than 1 bframe would be the same thing.
Safest in terms of compatibility is packed bistream together with 1 bframe or just use a HT profile when encoding. -
This would also mean different cut point compared to I (?) key frames, right? You would be able to set end cut point at non-key frame, vs. start at non-key frame.Originally Posted by jagabo
Keyframes will be in the same place as the original file but VirtualDub will be able to seek them properly. Any piece of the original file you keep must start on a keyframe; they can end on any frame.Originally Posted by cheerful
This was my original posts regarding cut points
https://forum.videohelp.com/topic324523.html
We now have
P-P-P-P-P-B-P-P-P-P-P-B-P-P-P-P-P-B
So it should now be possible cut it to, for example, by removing the 1st 3 P frames.
P-P-B-P-P-B-P-P-B
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
Key frame editing?
By vato76 in forum EditingReplies: 3Last Post: 7th Jun 2011, 12:55 -
Xvid4PSP key frame interval setting?
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 30th Dec 2010, 23:19 -
How to cut xvid avi by a non-key frame
By Kirill in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 06:52 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 14:05
