what is the best way an the best program?an also rekeying frames?i need more info
Results 1 to 9 of 9
A dat file can be an mpeg file from a videocd or an extension used by some programs for a variety of files some of which may be avi or mpeg.
Open Virtualdub or virtualdubmod. On the File menu click open video, in the next panel on the lower left, tick the box that says "Ask for extended options after this dialogue" and then browse to select the dat file. When it opens there will be many options such as redriving key frames. Some versions have options for accepting partial mpeg files etc... The messages and options may vary a bit depending on the version of virtualdub(mod) but if it's a valid video it should work. You can then select new compressions options etc... and resave as an avi. Redriving keyframes will take a while depending on the filesize. -
well the dat is a bit damaged so i cant save it as avi with virtualdub
Rename to mpg and try MPEG Corrector or use the quick stream fix in VideoRedo.
right click on the file chose rename. ***.dat -> ***.mpg
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 08:39 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
Algorithm convert DAT to AVI
By Nemo_wf in forum Video ConversionReplies: 5Last Post: 5th May 2010, 03:18 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 04:14
