My encoding process keeps failing. When I click the little 'i' button to see the log, the process crashes.
Is the encoding log saved somewhere?
Thanks.
Will that tell me why the encoding failed?
I'm not looking for OS debug info, just the encoding log which ffmpegX creates.
Check the "Open a terminal window" option in the ffmpegX menu to see ffmpegX progress log in real time.Originally Posted by exekutiveJean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
It only crashes when the encoding fails. I think this is because of the huge volume of log data which mpeg2enc produces. I don't think I have this problem with the ffmpeg encoder. I'm pretty sure my boot drive is fine, but I'll try repairing anyways.
The terminal window thing was OK, but if the process crashed while I was away from the computer (which I usually am for encoding), I still wouldn't get to see it. Plus you don't get a progress bar this way.
I just wish ffmpegx would also write the log to disk, instead of just the screen. Are there any scripts maybe that could redirect the terminal output to a file?
Turn off ffmpegX progress sound after finished conversion
By c.eiermann in forum ffmpegX general discussionReplies: 2Last Post: 2nd Sep 2010, 20:56 -
HELP!!! ffmpegx progress zero kb
By smjsinclair in forum ffmpegX general discussionReplies: 6Last Post: 9th Aug 2010, 18:06 -
FLV Metadata(?) problem - ffmpegX Progress hangs at 96%
By ThomasAlbert in forum ffmpegX general discussionReplies: 8Last Post: 1st May 2009, 09:04 -
ffmpegx can't find Progress.app
By jagon in forum ffmpegX general discussionReplies: 5Last Post: 14th Dec 2008, 03:14 -
Problem with Ffmpegx v 009y: can't find progress.app
By cellocgw in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2008, 17:16
