TMPGenc gets the audio out of sync every time, always at the end of the first mpg. I joined them with a generic MPG joiner, and it plays fine in PowerDVD, but Spruce only loads in the first piece of it as though it had never been joined. For some stupid reason, Spruce won't let movies play continuously, so if I just import all four files, you will be taken back to a menu at the end of each one when trying to watch the movie.
i know this sounds quite long winded but i am a newbie and i had a brain wave so i tried it and it worked perfectly the first time!!!!!!
first de multiplex the sound from the video using TMPEGEnc then get rid of the video files and use a program called twins file merger to join all the .mp2 files together (before its registered it will only allow 2 file at a time to be joined). this will give you the full length movie sound....
Then join all 4 mpegs of the movie in TMPEGEnc so it will be the full movie but the sound will be out of sync.
simply demultiplex the whole movie again and delete the mp2 file it creates then rename your .m2v (video) file to the same as your .mp2 (sound) file and perform a simple multiplex using the svcd (vbr) preset
And there you go ....perfect quality video and sound all in sync (This was all done on my AMD-k62 500 with 196m RAM so anyone with a faster computer it sould be alot faster for)....
HOPE THIS HELPS....... I am off to watch my perfect quality svhs version of this magnificant film now so see you soon
Cartman, you are the ******* man. I'm burning my perfectly in sync, seamless movie to DVD right now. Thanks for keeping me from pulling my hair out in frustration.
You really are the man Cartman. Credit where it is due. I was having the same problem and now thanks to you it is sorted.
You the daddy!
Newb Help Please - LOTR Extended Edition
By dpend in forum Blu-ray RippingReplies: 7Last Post: 5th Jul 2011, 12:21 -
LOTR extended editions hits bluray - you buying?
By yoda313 in forum Off topicReplies: 1Last Post: 20th Apr 2011, 07:14 -
Born of Hope - LOTR fan film
By freebird73717 in forum Off topicReplies: 0Last Post: 23rd Jan 2010, 14:19 -
LOTR Bluray preorder now available - theatrical release only for now
By yoda313 in forum Off topicReplies: 3Last Post: 16th Jul 2009, 17:52 -
Multiple DVDs one file(LOTR EEs to be exact)
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 22:39
NP
