7777777
If your destination format is going to be MPEG-2 (for DVD authoring for example), you might look at the Hauppauge PVR-250. It has the connectors you are looking for. The software also has a high degree of control, so you can customise your recordings. I have this card myself, and it is amazing (hence my pimping it here...)
http://www.hauppauge.com/html/wintvpvr250_datasheet.htmYou are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Well i advice you to buy the same card i have then (germans knows what's good
But it seems terratec don't sell it anymore :/
This is my third card and so far the best
chipset philips ,ntsc,pal,secam support pal 60hertz of course(i use it everyday almost)
video inputs: s-video,composite,antenna
and last but certainly NOT least audio inputs
+ some other stuff i never use like tv remote or even the radio or tv tuner lol..it's complete
price is reasonable i bought it something like 60€(+/-) one year ago.
you can make yourself an opinion by looking here
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 22:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 02:41 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 17:46
