Hi -
I went to a site with streaming media and looked in my temp folder for the actual video file. Found it! It was a 20 meg .dat file, which I have not been able to play back. However from the pathname to that file I know that what I was watching in my browser when at the actual web page was really a .wmv file. I am virtually positive that the .wmv file is buried somehow inside that .dat file. I have tried renaming it to .wmv but that doesn't work.
The reason I believe this is that the pathname to the file looked something like this:
www/MusicVideoWebPage.com/subfolder/FavoriteVideo.wmv?/otherFolders/FavoriteVideo.dat
So, how the heck can I somehow open the .dat file and look inside it and extract out that .wmv file?
Thanks!
I found the answer to my own question.
The program WM Recorder works like a charm! It stores all the files int he correct video format in a folder called "Recordings" in its folder under Program Files.
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 19:57 -
Streaming WMV leaved DAT file in Temporary Internet ???
By paj692 in forum Newbie / General discussionsReplies: 18Last Post: 17th Oct 2008, 16:02 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 17:32
