NTSC Interlaced Video.
I want to remove some of the noise if this is really noise or just pixelation in the video. I'm still not sure what filter to use because I think NeatVideo 2.0 would just be to strong in this case. Don't want to loose all my detail.
I'm planning on using the fill filter to cleanup the noise near the bottom. I'm not sure what type of noise or pixelation is caused in the blue/grey shirt, but it drives me crazy when I what it on TV.
I'm not sure how to clean this up since I don't know what it is for sure.
This one show really bad on the screen during playback. Again not sure if this is noise or just pixelation. Need a filter to clean this up if possible, just not sure which one.
Again you can see the noise on the TV screen, but not sure whats best to clean it up a little.
Thanks.
Matt
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Closed Thread
There's really nothing you can do here. Nothing at all.
One post per sugject is enough. Please don't double post. Continue in: https://forum.videohelp.com/topic331507.html#1716810
Moderator redwudz
Do I need a noise filter for Senn plug-on transmitter ?
By AAC in forum AudioReplies: 1Last Post: 15th Aug 2008, 12:55 -
Video: noise reduction filter for MPC
By bonanza in forum Software PlayingReplies: 1Last Post: 9th May 2008, 11:18 -
Chroma Noise Reduction filter for Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 09:43 -
Avisynth noise filter like convolution3d but newer?
By freebird73717 in forum RestorationReplies: 4Last Post: 18th Jun 2007, 18:03 -
How to emulate the Video Noise filter in premiere pro on TMPGENC Express 4?
By hanugro in forum RestorationReplies: 5Last Post: 25th May 2007, 04:11
