Hello everyone,
I'm having a bit of trouble with my H.264 settings and a movie DVD, Superman Returns. I set the target file size to 1405 MB (due to the movie's length of 2:27:58 (147.967 minutes)), the aspect ratio to 2.35:1, and clicked "auto". I then manually set the video with to 720 x 304 pixels, without changing the video bitrate. The goal is to achieve more detail with the same file size. After a couple more adjustments in the options tab (CABAC, lanzcos, multi-hexagon, two-pass encoding) I hit the "encode" button, and it starts encoding.
When it's done, I first check the file size, and it's nowhere around the estimated 1405MB. And with a bitrate of only 729 instead of the desired video bitrate of 1185 that's understandable, and confusing.
What am I doing wrong? Isn't it possible to set the video bitrate regardless of the video size? I'd be thankful for any piece of advice.
I think the encoder finds that "this bitrate gives all the space needed for accurate compression with this codec and these settings," and doesn't know what else to use the extra bitrate for. Hence it uses a lesser bitrate than you specified.
ffmpegX suggests 641 kbps (577-705) is good, more than 705 would be excess. H.264 is just that efficient. You want 1185 (185%!), you get 729 (114%). It would seem you already get excellent quality?
To get a little bit more visual quality, you could play with the quantizer value.
You could lower the Qmin a bit to get a larger output file, as lower values mean more quality. The developer suggests it is no use going lower than "10" for H.264.
You could set Qmax to the same value as Qmin to get a fixed quantizer and variable bitrate, which is quite close to what is perceived as constant quality. This would disregard your set bitrate and use whatever it needs. This also makes a second pass useless (there is nothing to optimize).
It would be trial and error to get close to your desired output file size, though.
If your source is a PAL DVD, then you have 576 vertical lines of resolution, including the 16:9 letterbox bars, leaving ~436 lines for the picture. So, instead of 720x304, you might also go with a bit larger size to get a larger, higher resolution file. 976x416 would fit nicely with a 1185 kbps bitrate.
Thanks for replying so quickly, Case.
Yeah, I figured I could play a little with the quantizer values. I just find the values so confusing and unpredictable. E.g., if lower quantizer values mean more quality, and by setting Qmin=10 and Qmax=51 you kind of set a range of quality, don't you? Does this also mean that the encoder doesn't necessarily need to compress the picture according to the Qmin value all the time, in order for it to stay in my desired bitrate? Meaning, it could just as well set Qmin=22 in one frame, and Qmin=10 in another, depending on the image, motion, whatever. If this is true, then why bother with the preset Qmin=22/Qmax=51, and why not just leave it at Qmin=10/Qmax=51, thus using the full range for H.264?
One other thing, in the summary tab it says that the source material's resolution is 720 x 576 pixels. Though, if said source is played on a DVD player (VLC), the actual screen size in 100% view isn't the resolution stated in the summary tab. So, what is the actual resolution of a DVD movie? Is it equal to 976x___? Because I don't want to blow up the image, as the developer doesn't suggest using a video size bigger than the source's.
I'm sorry for all the questions. As you can see, I truly am a newbie when it comes to all this digital video technology ... Hope to read from you people soon. Thanks anyways.
Someone that knows a good deal more than me about quantizer matrices should answer your first question.
PAL DVDs are normally 720x576, but are stretched to 16:9 or 4:3, whichever of the two aspect ratios is set. You could say the pixels aren't square on DVD. (See enlarged picture.)
So a 720x576 DVD frame may be displayed on a computer screen as 1024x576 (16:9), keeping original height as VLC does, or 720x404 (16:9), keeping original width as some QuickTime aware apps do. Image scaling filters smooth things out so the stretching isn't noticeable.
Video resolution (image size) calculator
By headless chicken in forum MacReplies: 10Last Post: 15th Jan 2011, 17:17 -
Studio 9.4.3 - Video image size too large
By rporayko in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2009, 16:58 -
working with h.264?
By midnait in forum EditingReplies: 8Last Post: 23rd Jan 2009, 00:25 -
Suggested video resolution to avoid overscan?
By andy_blah in forum Video ConversionReplies: 1Last Post: 14th Sep 2008, 04:13 -
Bitrates really high in H.264 files
By limeyx in forum ffmpegX general discussionReplies: 3Last Post: 16th Dec 2007, 18:55
