Hi, this is a bug report mainly, I thought it may be useful.
It happens after the burn is complete (using copy to dvd) so its not a major problem as everything has finished when it happens, it happens everythime I use SVCD2DVD. I hope its of some use.
btw, the only log file/folder I can find is a changelog file, not like the older versions, ...maybe the problem ?
..Also what happened to neroBurner?
Regards Anx
Version: SVCD2DVD 2.5
Build: 2.5.2720.15883
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.x24919c2ff8f0c 9b2()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Neroburner is gone, IMGBurn is the recommended method. Try it and see if the error goes away.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
.VOB to .AVI Encoding Error Bug
By spinzore in forum ffmpegX general discussionReplies: 1Last Post: 27th Aug 2010, 01:51 -
DeVeDe 3.16.9 build 2 Mencoder "bug" error under XP64
By mail2tom in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 19:35 -
[Bug] Error message weirdness
By Case in forum ffmpegX general discussionReplies: 0Last Post: 7th Jun 2007, 16:36
