I am trying to convert some saved Real media files (.rm) to .mpgs to view in Quicktime. I have Cleaner 5.1, and when I try to convert using that program, I get a bunch of errors. Cleaner can't (or won't) even open the .rm file. I know they're good files because they open in Real player...I just hate Real player.
Can anyone give me any advice on this? I use an iMac G3, 400 MHz, 512 MB RAM, OS 9.2.2.
Thanks,
Michael
HI
I have a PC , however have been trying the same thing for a while . I tried programs such as EO Video and Tinra , but no joy. Anyway I do not know if this would cross over to a MAC , but found the best way was the screen capture program method. WIth an Athlon 1.1ghz I can capture 25 frames per second at 352x288 with sound in sync. I find that if u watch the realmedia clip in 100% size (not full screen) you can eliminate a few of the blocks. You may have a screen capture program out for the MAC , I used Hypercam for the PC.
Anyway best of luck
Scouse
DVD to mpg converting....
By jay_lubb in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2010, 05:31 -
Converting .mpg movies
By baysee in forum MacReplies: 14Last Post: 25th Sep 2009, 06:11 -
Trouble converting mpg
By Jeffrey99 in forum Video ConversionReplies: 4Last Post: 13th May 2009, 06:59 -
Converting .ts to .mpg (HD)
By tomerwiz in forum Video ConversionReplies: 7Last Post: 8th Nov 2007, 14:48 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 09:03
