    Mar 2007
    Australia
    hello :)
    I recently converted a folder full of good quality camcorder .MOD files into .VOB.I used Super converter which did the job very quickly but gave poor results.My question is how can i get rid of the blockiness from these files.I have played around with virtualdubmod and the various filters including MSU Deblocker but I can't produce the results I am after.I also stupidly deleted my original .mod folder
    any help much appreciated :)
    image below is the worst of the blocking
    Use a better mpeg2/dvd converter than Super or increase the video bitrate. Or have you deleted your camcorder source files?
    Mar 2007
    Australia
    yes I accidently deleted the camcoder files.I have no originals
  4. i can't see your image, but i'm usually happy with msu deblocker.
    if the blocking is very bad then most of the time you won't get a really great result. once picture detail is gone it can't be magically brought back.
  5. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    open your file to virtualdub mpeg2
    Load the following filters in the specific order:
    deinterlace (unfold)
    MSU Smart Deblocking 0.8
    Video Denoise 2.0
    deinterlace (fold)
    see the results. If you don't like them, add
    neatvideo (the free version)
    try the various filter presets to see if there are results that you like better.
    If you still don't like the results, then learn avisynth and try your luck with the filters they offer there.
    Mar 2007
    Australia
    thankyou very much i will keep that in mind
