    Apr 2007
    Argentina
    Hello guys,
    I'm trying to encode an AVI, adding subtitles,
    to DVD Mpeg2enc, decoding with QT.
    I usually use the same configuration and everything works.
    But with this particular movies, It seems to finish the process in one minute
    (there are 45 or 90 minute movies), but I only gets a 1 second m2v.
    Any help will be great!!
    Here is the info:
    INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
    Sun Jun 17 03:26:53 ART 2007
    INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
    ++ WARN: [mpeg2enc] MPEG bitrate must be a multiple of 400 - rounding up
    INFO: [mpeg2enc] SETTING AltiVec for MOTION!
    INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
    INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
    movtoy4m
    Copyright 2002-2006 Johan Lindstr??m
    All rights reserved..
    ++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=512x384, frame rate=24000:1001 fps)!!
    INFO: [yuvscaler] input: frame size: 512x384 pixels (294912 bytes)
    INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
    INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
    INFO: [yuvscaler] input: interlace: none/progressive
    INFO: [yuvscaler] input: sample aspect ratio: 1:1
    INFO: [yuvscaler] from 512x384, take 512x384+0+0, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] scale to 512x384, 512x384 being displayed
    INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
    INFO: [yuvscaler] frame rate: 23.976 fps
    INFO: [yuvscaler] Scaling ratio for width is 1 to 1
    INFO: [yuvscaler] and is 1 to 1 for height
    INFO: [yuvscaler] Specific downscaling routing number 4
    INFO: [yuvscaler] output: frame size: 512x384 pixels (294912 bytes)
    INFO: [yuvscaler] output: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
    INFO: [yuvscaler] output: frame rate: 24000/1001 fps (~23.976024)
    INFO: [yuvscaler] output: interlace: none/progressive
    INFO: [yuvscaler] output: sample aspect ratio: 1:1
    INFO: [mpeg2enc] Selecting DVD with dummy navigation packets output profile
    INFO: [mpeg2enc] Assuming norm NTSC
    ++ WARN: [mpeg2enc] Interlaced encoding selected with progressive input!
    ++ WARN: [mpeg2enc] (This will damage the chroma channels.)
    INFO: [mpeg2enc] Encoding MPEG-2 video to /4400/1-2/The.4400.S03E01.E02.avi.ff.m2v
    INFO: [mpeg2enc] Horizontal size: 512 pel
    INFO: [mpeg2enc] Vertical size: 384 pel
    INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
    INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
    INFO: [mpeg2enc] Bitrate: 1703 KBit/s
    INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
    INFO: [mpeg2enc] Field order for input: none/progressive
    INFO: [mpeg2enc] New Sequence every 9999 Mbytes
    INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
    INFO: [mpeg2enc] Search radius: 16
    INFO: [mpeg2enc] DualPrime: no
    INFO: [mpeg2enc] Using one-pass rate control
    INFO: [mpeg2enc] GOP SIZE RANGE 7 TO 15
    INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
    INFO: [mpeg2enc] Progressive format frames = 0
    INFO: [mpeg2enc] Using default unmodified quantization matrices
    INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
    INFO: [mpeg2enc] PAR = 1
    INFO: [mpeg2enc] Creating worker thread 0
    INFO: [mpeg2enc] NEW GOP INIT length 15
    INFO: [mpeg2enc] Worker: getting
    INFO: [mpeg2enc] Working: stripe 0/1 1
    INFO: [mpeg2enc] Worker: stripe 0 done
    INFO: [mpeg2enc] Enc1 0 0( 0) I q=3.00 [100% Intra]
    INFO: [mpeg2enc] Enc1 1 1( 1) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 2 2( 2) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 3 3( 3) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 4 4( 4) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 5 5( 5) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 6 6( 6) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 7 7( 7) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 8 8( 8) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 9 9( 9) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 10 10(10) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 11 11(11) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 12 12(12) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 13 13(13) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 14 14(14) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 15 15( 0) I q=3.00 [100% Intra]
    INFO: [mpeg2enc] Enc1 16 16( 1) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 17 17( 2) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 18 18( 3) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 19 19( 4) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 20 20( 5) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 21 21( 6) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 22 22( 7) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 23 23( 8) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 24 24( 9) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 25 25(10) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 26 26(11) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 27 27(12) P q=3.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 28 28(13) P q=3.00 [10% Intra]
    INFO: [mpeg2enc] Enc1 29 29(14) P q=3.17 [9% Intra]
    INFO: [mpeg2enc] Enc1 30 30( 0) I q=3.00 [100% Intra]
    INFO: [mpeg2enc] Enc1 31 31( 1) P q=5.28 [3% Intra]
    INFO: [mpeg2enc] Enc1 32 32( 2) P q=6.14 [4% Intra]
    INFO: [mpeg2enc] Enc1 33 33( 3) P q=6.00 [0% Intra]
    INFO: [mpeg2enc] Enc1 34 34( 4) P q=5.59 [0% Intra]
    INFO: [mpeg2enc] Enc1 35 35( 5) P q=4.83 [0% Intra]
    INFO: [mpeg2enc] Enc1 36 36( 6) P q=4.76 [0% Intra]
    INFO: [mpeg2enc] Enc1 37 37( 7) P q=4.89 [0% Intra]
    INFO: [mpeg2enc] Enc1 38 38( 8) P q=5.27 [0% Intra]
    INFO: [mpeg2enc] Enc1 39 39( 9) P q=4.94 [0% Intra]
    INFO: [mpeg2enc] Enc1 40 40(10) P q=5.24 [0% Intra]
    INFO: [mpeg2enc] Enc1 41 41(11) P q=5.60 [0% Intra]
    INFO: [mpeg2enc] Enc1 42 42(12) P q=5.78 [0% Intra]
    INFO: [mpeg2enc] Enc1 43 43(13) P q=5.97 [0% Intra]
    INFO: [mpeg2enc] Enc1 44 44(14) P q=6.38 [0% Intra]
    INFO: [mpeg2enc] Enc1 45 45( 0) I q=11.53 [100% Intra]
    INFO: [mpeg2enc] Enc1 46 46( 1) P q=8.33 [1% Intra]
    INFO: [mpeg2enc] Enc1 47 47( 2) P q=9.01 [0% Intra]
    INFO: [mpeg2enc] Enc1 48 48( 3) P q=8.62 [0% Intra]
    INFO: [mpeg2enc] Enc1 49 49( 4) P q=9.75 [0% Intra]
    INFO: [mpeg2enc] Enc1 50 50( 5) P q=10.00 [1% Intra]
    INFO: [mpeg2enc] Enc1 51 51( 6) P q=10.72 [1% Intra]
    INFO: [mpeg2enc] Enc1 52 52( 7) P q=11.17 [1% Intra]
    INFO: [mpeg2enc] Enc1 53 53( 8) P q=11.55 [1% Intra]
    INFO: [mpeg2enc] Enc1 54 54( 9) P q=11.45 [1% Intra]
    INFO: [mpeg2enc] Enc1 55 55(10) P q=11.25 [1% Intra]
    INFO: [mpeg2enc] Enc1 56 56(11) P q=11.91 [1% Intra]
    Aug 2005
    Palo Alto, California USA
    Have you verified whether QT can play the file? If it can't (and my guess is that it won't), then you can't expect ffmpegx to work with "decode with QT" selected.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    It might not improve your encoding, but another problem is:
    INFO: [yuvscaler] [...]
    INFO: [yuvscaler] output: frame size: 512x384 pixels [...]
    512x384 isn't a valid size for DVD. You'd have to scale up (or down) to one of the valid DVD frame sizes. For your convenience, the Autosize menu in the Video tab has a "DVD" preset, which sets the video size to 720x480 (for material with NTSC Film framerate).
