I have a large movie and want to keep the video quality so trying to split it with DVDFab Platinum v3 to fit on two DVD disks.
The app is able to compress the movie to DVD-5 etc but when I click on the SPLIT button nothing happens.
Can anyone advise on this. The movie VOB files are fine.
well you could author with dvdshrink & vob blanker
rip to the HHd
blank half the vobs ( 2nd half ), then use shrink to create the 1st disc
then use vob blanker restore the blanks ( 2nd half ), and blank the first half and use shrink to make the second disc
if done correctly at the chapter markers,
there will be NO compression, and the movie will be split between the discs and you can even keep the menus ( if you want )
use whole disc mode to author, the blanked vobs will not be used by shrink
or re-author if you wish to run the movie direst with no menus, -
With one large movie Video Redo worked fine, split it and burnt to two DVDs and played OK
With another one it simply would not iniatate the split.
Anyone know what characteristics would make it not split the second movie. Both were VOB files.
DVDFab 5, Platinum Question
By Ric2L in forum DVD RippingReplies: 3Last Post: 18th Jan 2009, 18:19 -
DVDfab Platinum
By jason in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 12:05 -
Question on DVDFAB PLATINUM 4
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2008, 21:43 -
DVDfab Platinum question.
By AlecWest in forum Authoring (DVD)Replies: 5Last Post: 30th Dec 2007, 19:46 -
DVDFab Platinum
By bigdogdadog in forum Newbie / General discussionsReplies: 9Last Post: 3rd Nov 2007, 16:06
