i used super to convert my rmvb file to avi, i want to leave the video setting and the audio setting as the original, so i checked video stream copy and audio stream copy, but i get an error saying possible causes of Encoding Failure an ERROR has occured while encoding the most common possible reasons causing error:..... i am using xp codec pack and real alternative, HELP? i selected MEncoder
You can't put real video and audio in an avi.
You have to re-encode.
go to Xvid / mp3 -
stream copy, copies the video stream that is there, you can check no change for resloution
for bit rate, you should try gspot or media info and see if they will give you any bitrate data
if you can get the video bitrate set super one or two values above
that and your new avi should be find
set the audio for mp3 and 128k
Super 8 help
By overgroun in forum Video ConversionReplies: 4Last Post: 28th Dec 2011, 23:47 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 08:29 -
SUPER
By Flying Doctor in forum Video ConversionReplies: 17Last Post: 6th Jan 2008, 06:52 -
SUPER
By OG24 in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 17:11
