I have an avi file 4:3 (the picture inside is 16:9 with black areas at the top, bottom and sides)
I need to convert this file to 16:9. I tried to do it but the quality I get is not good.
If you gave some useful details you might get useful answers. Something like :
1. What sort of avi file ? AVI is a container. What codecs are being used ? what is the resolution ?
2. What tools are you using at the moment ?
3. What output do you require ? AVI, DVD ?
Based on what little information you have given, all I can offer in return is crop the black off and re-encode with a suitable codec at a good bitrate and you will get what you want.
Give me more details to work with, and I can give you a more detailed process.Read my blog here.
You cannot turn a pigs ear into a silk purse.
It's going to look stretched whatever you do.
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
