I am suddenly having a ground loop problem. The cable is causing my subwoofer to hum on my Home Theater system. If I unplug the cable all is fine. I tried to use a $10 ground loop isolator from a local store, which did stop the humming, but it also disrupted my digital/HD cable to the tv, to the point of unwatchable because of constant stuttering/pausing. I was wondering if anyone know's if an Isolator like this would work, and still keep the video quality as it should be?
Jensen Cable TV RF Isolator Model VRD-1FF PDF
What We Do In Life, Echoes In Eternity....
The loop is probably caused by plugging power into separate circuit breakers. Plug in power to the same circuit where possible. Think back which connections were made recently.Originally Posted by Denvers Dawgs
Yeah try different AC outlets or run a wire between the sub chassis and the amp,an Isobar powerstrip may also help.
Take a look here for more answers:
http://forum.ecoustics.com/bbs/messages/34579/180767.html -
I have tried to plug the subwoofer into the same powerstrip that has the tv, HT system, cable. And I also tried to plug the sub into a different ac outlet and it still did the humming.
I haven't changed anything with the setup. It just one day started humming.What We Do In Life, Echoes In Eternity....
Sound only coming from subwoofer
By jeanpave in forum AudioReplies: 11Last Post: 5th Oct 2010, 00:24 -
Encore CS4 loop point problem
By sebaz in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Jul 2010, 14:14 -
How to filter out a ground buzz
By pdx10 in forum AudioReplies: 4Last Post: 24th Mar 2009, 09:14 -
Subwoofer and speaker problems
By HartsVideo in forum AudioReplies: 10Last Post: 20th Sep 2008, 12:18 -
Subwoofer Help
By levon in forum AudioReplies: 9Last Post: 3rd Sep 2008, 13:41
