Is AviSynth support in SVCD2DVD something that people would be interested in?
Basically, in the most simplest scenario you could have an "input.avs" text file with this single line :
DirectShowSource("C:\movie.wmv")
and then input.avs could be an asset of SVCD2DVD.
So you could convert any file to DVD, as long as you have the DirectShow filters to play the file in WMP.
Obviously, for the more seasoned AviSynth users, any script which produces interleaved video and audio frames will work. So all your favorite complex scripts would work too...
Results 1 to 13 of 13
You can count me as interested. 8)
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Dwight: the latest build: 2.5.2725 has this added now. Any avs related findings (good or bad) can be posted in this topic please.
Thanks.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Chrissyboy,
Nice job on the avisynth script feature. What I would really like to see though is a batch operation or a command line option for SVCD2DVD. Is there any chance of that happening in the near future?
I realize we can start more than one instance of the program but I prefer to not bog down my machine too much with encoding chores. I would like to be able to run SVCD2DVD sequentially to encode multiple movies.
Thanks, -
Works great for me. Good speed (18 fps) even with multiple filters running. Thanks for the flexibility.
Dwight
- Herm Albright
hmmmmmmmm don't know how I missed this!!
Do files loaded with DirectShowSource statement
automatically pick up .sup subtitles? Or better yet,
can you place a VobSub statement in the script to
hard code idx/sub subtitles?http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
Hmmmmmmm I'm gettin' nowhere fast. If I have this input.avs
DirectShowSource("movie.avi")
VobSub("movie")
and try to import it I get "unable to import asset"
if I have this input.avs
it appears to be loading, but it never makes the asset list and the program hangs.
edit: btw I have other converters on the machine that load all
input with DirectShowSource statements and have converted
the .avi movie in question so the DirectShow filters and the
input .avi file are not hosed.
Have you tried importing those scripts into media player or mpc?
Dwight
- Herm Albright
It's not that it's that big a deal to do SubToSup but then you run into the
color change hassle. White subs with black outline become hot pink with
green outline and it's really an eye strain.
It would be nice if I get
get it to do simple .avs scripts.http://milesaheadsoftware.org/
That rules out an error in the script. It is weird.Originally Posted by MilesAheadDwight
- Herm Albright
I'm just thinking, is there any possibility that SVCD2DVD takes note of where stuff
is during the install? Maybe when I install some other encoders it may change the
location or something in the registry to do with AviSynth? Seems strange.
I do have a gizmo to change the subtitle colors. I haven't looked at it
since the last update but I hope the author made it easier to change
the color palette or whatever it is that controls foreground background
border color etc.. I mess with it and get it to work but by the next time
I forget how to use it!!
If you're in a hurry then it's a hair pull.
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 12:39 -
GUI Encoders with Avisynth support?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 13th Dec 2011, 05:27 -
help for svcd2dvd
By dougal69 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2011, 17:05 -
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 11:45
