  1. The person talking is too close to the microphone (I think that's why) and the Ss and such are distorted and sharp. I tried filtering it out using it's fingerprint and noise reduction in Goldwave but it makes the whole file odd. Anyway if anybody knows a way to get rid of or at least lessen this it would be great. This is also a recording on an audio tape if that helps any.
    Short WAV of sound
    USA
    You might take a look at this post, at least for the 'Essses' problem. https://forum.videohelp.com/topic330172.html#1707918
  3. Ok, I read that thread but since there was no real resolution it didn't quite help. I tried FloorFish De-Esser but it didn't really seem to do anything. The one that did seem to work is Renaissance DeEssser. It's expensive but they have a trial if you only need limited use. Here is the edited file.
    Edited Sharp Essss
  4. Member grannyGeek's Avatar
    Apr 2006
    Land of the Rising Sun
    You could take a look at the demo of Magix Audio Cleaning Lab
    http://site.magix.net/english-us/home/free-download/
    ACL has some pretty decent (tweakable) presets to de-hiss and de-noise, and does have a De-Esser (but not in the main interface with the other de-noisers, take a look at the help files to track down where and how to use it).
    I've never used de-esser, but other settings do pretty well for me.
    Demo won't let you save your work, but you can get a clear idea of how well this app does or doesn't meet your needs. (not TOO expensive, I think around $40 USD these days.)
    grannyGeek ~~
    Antique Newbie
  5. Member Soopafresh's Avatar
    Jan 2004
    If that's a relaxation tape, fuggetaboutit.... Find something else on the internet. There are tons of similar scripts to relax you.
  6. Originally Posted by Soopafresh
    Yeah it's not going to be perfect and I wish I could just get something else but it's a sentimental thing (I wouldn't spend all this time for nothing ). I think that's about as good as it's going to get (I don't want to spend another 3 hours trying to tweak insesantly).
