some questions from someone who hasn't a clue so I'll be grateful for your help:
1) what software do you use to create a DivX vcd/dvd (are they even burned to dvd?)
2) the DivX files I've download are generally about 600mb so they would be burned to CD?
3) I won't have to wait for hours of encoding, it's like having an mpeg ready to burn to dvd?
4) am i wrong in thinking that the DivX Players also play Xvids?
TIA
1. You use the Divx or Xvid codec and a front end program to feed the codec. Some programs for DVD to Xivd/Divx, AutoGK, FairUse Wizard, avi.NET and a few more. You can burn them to DVD or CD as a data disc.
2. Probably about 700MB, and yes, they are set up to burn as a data CD. However, you would get much better quality creating a 1500MB file.
3. Yes, it will take a few hours or more, depending on your CPU speed.
4. If the Xvid uses the same format/settings as a Divx format that is Divx player compatible, they are more or less interchangeable. -
I think I've phrased the question incorrectly - or I've got this totally wrong - what I mean is say I've download a DivX file and I want to put it onto a CD to play in a DivX player.. that won't take hours will it? I was assuming it doesn't need encoding (if I'm using the correct terms), it would be like having an mpeg file ready to make a dvd with, like when I've converted a divX to Mpeg the mpeg only takes about 10 mins to put on dvd? The only reason I was thinking of buying a DivX player was it would save hours of encoding to mpeg and I could put the divx straight on cd and play it
Just create a data CD with ImgBurn or burnatonce. Takes < 4 minutes on my system.
/Mats -
Not a problem.
Like Mats said, just burn it to CD as data. You can also use a DVD and put several on there as data and your player should work the same with them. Many of the Divx/Xvid files off the net that are about 600 - 700MB were made for playback on a Divx player. You may find a few odd ones, then you might have to re-encode or modify them slightly.
Questions about few things. DVD to Divx with permanent subtitles, etc
By Earthling2000 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2009, 13:15 -
SABA Dvd/Divx player questions
By ctown29 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jan 2009, 14:46 -
Bit rate for DV(720x576px) over Xvid/X.264/DivX? (and some other questions)
By Gew in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2008, 08:03 -
Many questions on MKV to AVI for DivX player
By MasterRoshi in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 11:42 -
DivX DVD Player questions
By MasterRoshi in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2008, 13:41
