Hello,
I am trying to transfer some VHS tapes onto my computer for basic editing. What is the easiest way go about getting the video onto my computer?
Thanks,
Michelle
Going to need a little bit more info before anyone can help you...
What do you consider to be basic editing? Cutting, merging, cross-fading, etc.
What is your final output to be? DVD, VCD, Digital file, tape?
Your profile is vague - do you have a capture device or DV cam?
VH -
if you do not have a dvd recorder, I;d recommend the panasonic ES$%V combo, it is very good for good quiality vhs recordings.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I wrote an article here that's a good starter that covers just about everthing you should know before purchasing anything:
http://www.nepadigital.com/articles/analog-capture.php -
I intend to do cutting and the final output will be DVD. I have a DV cam and a capture device. I just bought a Dazzle Hollywood DV Bridge, but neither of my computers will detect it.
I tried connecting the vcr to the video camera, and the video camera to my computers firewire. However, I get a "buzz" sound on the audio.
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 12:50 -
VHS-C transfer: adapter or camcorder?
By moxiecat in forum RestorationReplies: 31Last Post: 15th Jun 2011, 17:18 -
New problem with VHS transfer
By lgh529 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2008, 21:02 -
Capture of VHS Film Transfer
By mcpogue in forum RestorationReplies: 5Last Post: 18th Mar 2008, 18:03 -
How to get DVD Quality on a VHS Transfer?
By Nitro89 in forum Capturing and VCRReplies: 28Last Post: 10th Nov 2007, 00:26
