I published a Windows MovieMaker file to my desktop and after 23 tries it finally saved he file in a .avi format. It is a 38 minute movie roughly 7+ GB in size
I am using CUCUSOFT Pro converter program to convert from .avi to MPEG2. The program gets to 26% complete and then I get the error message Avi2MpegMain has stopped working.
Help
Gunslinger, thanks but I am a novice. What is basic avi script and where do I get it?
AVS is the extension for scripts used by avisynth. Avisynth is a text based frameserver that is very powerful once you get your head around the fact that it's basic frontend is notepad. You write scripts to tell it what to do with your video. You can find links to most of the useful tools in the tools section, or by clicking on their names in the posts here (the first reference is a hyperlink).
FitCD is a clever program that can create a basic avisynth script for you. Just load your video in, tell it you want to create a DVD, and save the script. You can then load this into your encoder instead of the avi file, and your encoder will see the video.
If this seems a little daunting, give DVD Flick a try. It is a simple but powerful conversion and authoring tool, and completely free.Read my blog here.
RAR file conversion issue
By illyad in forum Video ConversionReplies: 4Last Post: 11th Jul 2010, 10:53 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 09:52 -
Conversion Issue
By yousif5877 in forum Video ConversionReplies: 4Last Post: 13th Feb 2008, 04:16 -
File conversion or Frontpage issue?
By ANDREWBALK in forum Video ConversionReplies: 1Last Post: 6th Aug 2007, 10:55 -
CUCUSOFT file conversion issue
By steve7510 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2007, 21:05
