Results 1 to 12 of 12
    Jun 2007
    South Africa
    what is the best capturing hardware?for vhs capturing?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    For VHS capturing, I use the Hauppauge PVR-250. It's a hardware MPEG-2 encoder that does wonderful capturing. You can specify frame size, and the bitrate (even so far as to choose CBR or a custom variable bitrate). Plus the best thing is, it ignores Macrovision, so if you are capturing a commercially made tape, this feature can be a god-send. Other people I know have had good results using a DV capture card in conjunction with some sort of TBC (time base corrector).
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
    Oct 2006
    Australia
    Does the capture device make a big difference in quality or is it more to do with the decoder/software used?
    Jun 2007
    South Africa
    THE TBC helps a lot
    Oct 2006
    Australia
    So what brands generally use a good TBC?
    Can you recommend something. . .
    Jun 2007
    South Africa
    i heard JVC does
    I'd have to suggest a Matrox RTX card. They run about $1000.
    Jun 2007
    South Africa
    and vcr's?
    Feb 2004
    Australia
    Q :
    what is the best capturing hardware? for vhs capturing?
    A :
    1: Considering cpu at 900mhz , if thats correct , is well behind for whats to be considered "best quality" capturing considering minimum specs required by modern hardware that connects to pcs these days .
    It may be worth checking out WinFast TV2000 XP in ebay (new and cheap) , if your looking for a cheap routine that might just get the job done , but you will need to do some trial and error tests using suitable compressors (codecs) if your aiming at anywhere near 25fps / full d1 pal resolution (720x576) ... it can be done . But you may need more hard drive space for temp recording storage .
    Or the alternative :
    2: Grab a dvd recorder , and possibly a video stabilizer incase one of your vhs tapes contain good old macrovision .
    All you need then is a dvd drive for the pc which will allow you to rip your recordings from the dvd discs , and you can edit the content in your own time . Reburning at 4x to dvd-r , but older hard drives tend to have problems when placed under load .
    Dont forget to set the dvd recorder to video mode when recording or you might end up with whats known as vro's which tmpgenc and ulead video studio 8 se (cheap in ebay) , can edit .
    Personally , go with the cheaper method for now if money is tight ... the winfast tv2000 xp also has a lot of online support if you need help getting it up and running , which includes myself .
    Just beware of available pc slots on your motherboard :
    Onboard agp / agp slot / pci 1 = share resources (do not use pci1)
    Pci2 / pci3 = share resources (only one slot may be occupied by a pci device , not both)
    Those lucky enough to have full sized motherboards :
    Pci4 / pci5 = share resources (only one slot may be occupied by a pci device , not both)
    For those with 3pci slots or less , to install an internal pci capture device would require the internal modem to be removed and replaced with an external modem , in order to prevent device conflicts and / or damage to pci component / pc .
    Note that this is only taking consideration of the specs OP has supplied about pc , and dose not reflect modern systems that including usb2 or firewire ports .
    Of course the information about slot arrangements applies to all systems .
    Jun 2007
    South Africa
    thanks but i need more info on the best vcr's to use with built in tbc
  11. Video Restorer lordsmurf's Avatar
    You should own several. A good JVC is a must, like the later-end 7000, 9000 or SR series. Some also have a Panasonic AG19870 or 1980 too. The JVC tends to do the most, between the two. And then a good VHS VCR from Sharp or Toshiba would be good.
  12. Preservationist davideck's Avatar
    Feb 2003
    USA
    https://forum.videohelp.com/topic328283.html
    https://forum.videohelp.com/topic287476.html
    Life is better when you focus on the signals instead of the noise.
