Holaaaaaaaa
I need help for capturing mpg1 in mmc 7.2, the problem is the noise in mpg.
Help Plezzzz.....
Had a problem like this, my only fix was to do a total re-install of teh ATI drivers, MMC stuff, if you look to the left of this page, and select the Capture Card in the What Is (Top Frame - Left), go down until you see Capture with ATI, follow the instruction on that page EXACTLY and you should not have any problems, I have done this at least twice with these instruction, and it worked both times.
Bud
Connecting the DDR and CD-Rom drives
By hellfire45 in forum ComputerReplies: 17Last Post: 4th Oct 2010, 02:57 -
Wanted: good/used DDR memory
By DirtBikeMike in forum ComputerReplies: 3Last Post: 9th Feb 2010, 13:54 -
From DV camcorder to DVD with Nero. helpppp
By kscott0986 in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2009, 10:17 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50 -
DDR vs DDR2
By CSULB71 in forum ComputerReplies: 2Last Post: 1st Jun 2008, 14:54
Holaaaaaaaa
